Instructions
You need to remove the front number (10 min) in order to remove the headlights. You can't replace the bulbs without removing the headlights. If you're only going to be replacing one, everyone is going to recommend replacing both so the colors match.
Instructions to remove number can be found in the garage. Nothing a little search can't help you with.
Good luck.
Ps what bulbs are you going to be putting in there?
Good luck.
rcs86
08-02-2016 06:52 PM
