Installed Dom's Navi -> Malfunction Indicator?
Old Apr 19, 2006 | 07:43 AM
bigdenis's Avatar
9th Gear
Unhappy Installed Dom's Navi -> Malfunction Indicator?
I just got Dom's Navi yesterday morning and installed it at night. The install went pretty smoothly. However, on my way home after doing the install, I noticed that there was a funny amber light on next to the key indicator lamp. I looked it up and found that it's the malfunction indicator lamp. Now, I'm almost positive that the light wasn't on before I did the mod.
Does anybody know if anything I did could have triggered this light to go on? e.g. could this light be set off by a cable / hose that I forgot to reconnect or a fuse that was blown, during installation, etc.
The only parts I tinkered with were the center console and the area behind the navigation screen.
Old Apr 19, 2006 | 08:23 AM
kennyc's Avatar
not vtech... VTEC!!!
uh... Dom's navi box should be installed in the trunk, between the navi cable and the navi box in the trunk.
IIRC, the instruction explicitly said do not install it behind the center console. Is that where you installed the box?
Old Apr 19, 2006 | 12:11 PM
bigdenis's Avatar
9th Gear
Nowhere in the instructions does it say not to install behind the screen. As a matter of fact it even states "the wire colors at the navi are the same as behind the screen". And I called and spoke with Dom about doing a behind the screen install earlier. Thanks though.
Old Apr 19, 2006 | 08:07 PM
bigdenis's Avatar
9th Gear
UPDATE: the light seems to have fixed itself!
Old Apr 19, 2006 | 09:36 PM
zeezz's Avatar
Team Anthracite Webmaster
i installed it behind the screen with no probs as well.
in hindsight, i probably should of taken the rear approach, as now i will have fun feeding my rear view camera to the front.
*smacks head*
EDIT: on the other hand, i remembered i also installed a relay back there behidn the audio headunit to get aux in / XM toggling... great sound quality.
Old Apr 22, 2006 | 06:26 PM
DeadLock's Avatar
Forced Induction
the sticker on Dom's piece says right on it, that the warantee is void if you install it in the rear of the navi...........but I have the PNP version, but it shouldnt matter......so I dont know.
Old Apr 23, 2006 | 06:36 AM
kennyc's Avatar
ok... so I am not going crazy...
Old Apr 23, 2006 | 10:46 AM
DeadLock's Avatar
Forced Induction
here is a picture I just took
Old Apr 23, 2006 | 01:23 PM
zeezz's Avatar
wow, mine doesnt' say that on the box. maybe cuz it's older?
Old Apr 23, 2006 | 07:46 PM
BigB2k5's Avatar
Mine does, but whats funny is mine had some kind of sticker on it before that seems to be removed and this one placed where the left overs are. It was a smaller diffrent sticker. I wonder what it said.
Old Apr 24, 2006 | 08:42 AM
palmultiacura's Avatar
The sticker comes off VERY easily....which I don't mind because I HATE peeling off a sticker just to have the sticky side stay on the box. Your sticker might have accidentally come off prior to you getting it.
Old Apr 24, 2006 | 09:01 PM
zeezz's Avatar
just to make sure i wasnt going crazy, i found my pictures..
see!
Old Apr 25, 2006 | 11:11 AM
rbf351's Avatar
Registered User
see!
same one i have, and it is installed behind the navi screen, been there almost 6-8 months, and not a single issue with it being back there
DeadLock's Avatar
Forced Induction
I think they have diff stickers depending on if its a PNP or not...........
Old Apr 27, 2006 | 08:21 PM
weedeater's Avatar
FWIW: whatever caused the MIL to come on was a temporary problem that went away and did not come back in X number of restarts. So the computer turned off the lamp. But the problem stays stored in the computer. If you can get the code scanned, you can see what it is and decide what to do with it. My guess would be that you pulled something loose with the key on and the computer detected it. The SRS computer is down there under the Nav so maybe you jiggled a connector or something.
Feb 25, 2020 09:57 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
bymotion
Nov 18, 2015 11:28 AM
HeloDown
Sep 8, 2015 06:51 PM
asahrts
Sep 4, 2015 05:55 PM
