Imate Pda2k With Acura Hfl
I finally got my IMATE PDA2K to work with the HFL. I had the 3500 Bluetooth Stack, & I found the 3900 Bluetooth Stack. I copied the Cab file into MY Documents then opened it up. Then I did a soft reset & it now woks with the HFL. It will never connect to the Acura Server. My main goal was too make it work with the HFL. If you have the Qtek 9090 or the Siemens SX66 this fix should work for those phones. You should back up your phone with Sprite Backup in case something does not go right. That Sprite & Resco (media suite) are 2 programs that are a necessity with your PDA phone. When you install a new "ROM" you should never reinatall with a backup but do each program one at a time. When you install a cab there is no need to do a hard reset.
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
sockr1
Oct 1, 2015 01:31 AM
asahrts
Sep 4, 2015 05:55 PM
