Imagine '04-'08 Acura TL nav buttons & features working on Nexus 7
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
![Im New](https://acurazine.com/forums/images/smilies/imnew.gif)
I've been wondering about this theory of replacing my original stock nav system with a Nexus 7 tablet. Only thing is, I don't want to fall short of all of the customizable options that come with the original nav system for the car or lose any of the functions of the steering wheel and dash buttons... (I like how you can add up 5 destinations at one time and get to them all in the best timely manner and things like that.) I hope you guys can help figure this out because this would be totally awesome to do
![Shocked](https://acurazine.com/forums/images/smilies/shocked.gif)
![Cocaine!](https://acurazine.com/forums/images/smilies/snort.gif)
It would be cool if there was an app you could load the TL satellite linked navigation system cd-rom onto so that you can use it through the nexus as well as rewire all the original wires to the nexus 7 via USB so that you can control their features and use the buttons to control the nexus as you would have with the original nav system from the dash and the steering wheel.
FEATURES
-Wireless nexus charging
-Rerouting all compatible buttons from the steering wheel and the dash it self so that they function with the nexus 7.
-Connecting a distance sensitive reverse camera that turns on and pops open on the nexus automatically when you put the car in reverse and manually if you just want to check it out while you're not in reverse.
-A front recording camera that can be turn on manually or automatically when you drive, (in case you ever need those recordings for insurance purposes.)
![Explode](https://acurazine.com/forums/images/smilies/explode.gif)
I know right, there's so much complicated things to do up there...
But I'm hoping someone with the right soldering, engineering, and app programming background can help put together something like this.
If anyone knows how to do any of these things, please, please help out so we can make this a real project and bring it to life!
PLEASE HELP BY POSTING PICS AND DETAILS, THANK YOU!
Inspired by 00g
what the fuck?
its IMPOSSIBLE to tie in nav to nexus 7.
the nav has its own eco-system, which is closed.
the nexus 7 has its own eco-system.
there is no possible way to bring the two eco-systems together.
if you want the buttons to retain functionality, simply DO NOT add a nexus.
If you want better navigation, better music player, better movie player, add a nexus 7.
let the OP have his pipedream!!!
![Blaze](https://acurazine.com/forums/images/smilies/blaze.gif)
the closest thing you can do, is have 4 or 5 different pieces of hardware. They wont interact with each other, because different eco-systems....but you can turn them on or off with physical buttons.
like for example; 1 piece of hardware for the front facing camera and another hardware camera for the rear. unless they come together, both of them will operate on their own software.
2; wireless charging has to be its own hardware.
3;nav has to be separate of tablet, because they cant interact with each other because of different operating system.
there's literally NO WORK arounds because everything is limited to hardware. and hardware is seriously lacking in this car. it simply does not have the processing power to do what you want it to do.
Sorry, this is a better idea!
Basically, keeping the nav system fully functional except, moving it under the cassette player and placing a nexus in it's position. This way, I wouldn't have to do any custom apps or rerouting or anything other than moving the nav under and poping in a new nexus.
However, I still need to figure out how to set up the reverse camera so that it automatically operates when I put the car in reverse and also be able to operate it whenever I feel like and the other thing is to have the front camera automatically record or whenever I feel like it. Is there a way to do this?
![what](https://acurazine.com/forums/images/smilies/what.gif)
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
Kiya (10-30-2015)
not being able to integrate the oem back up camera was the main reason i didn't do the tablet. there's some threads by people that have started researching this but you need to search for them in the audio/nav section. they're there but i don't believe there is a final, legit solution, which is why i stopped following those threads and gave up the tablet idea.
I hope they've found something by now. I'm still serching, because if I can't have the whole front camera recording, I can live with it, but the backup camera is a great feature to have. I found this video, hope it helps motivate you to try it out after all.
Cody Bechtold explained:
" I used a Rom called Autodroid (google), a USB OTC cable, a USB hub, and an Easycap with STK1160 chip, purchased at this link: I used a Rom called Autodroid, a USB OTC cable, a USB hub, and an Easycap with STK1160 chip, purchased at this link USB Audio Video DVR Capture Card VHS VCR TV to DVD Converter Adapter PC Recorder | eBay "
Registered Bunny
maybe now there are better solutions but i got over it and went ghetto style with a portable gps permanently mounted.
look forward to your install OP!
I think the best and easiest solution, albeit the most expensive, is to buy a new accord with car play. Then you get everything you want!
OP!!!
Bro no disrespect, but its not easy, if you took the whole navy system apart, than you know what you are dealing with, there will be some fab work that you will have to do, move wires. extend a lot of things, test and so on...
Trust me,, what your trying to accomplish, a lot of people did but with lots of work put in to it... make sure you take everything apart once, clips and shit will brake or damage some of the plastic... I didn't go that route.... I went with car pc. which was more work than anything i have ever done... but it turned out great!
FEATURES
Inspired by 00g
Acura TL with Nexus 7 with re-routed buttons. - YouTube
https://i.imgur.com/1J8odHA.jpg
As others have already stated, you're asking for not only the impossible, but also the pointless. The Nexus 7 has Google Maps (aka navigation). Press the microphone button, "take me home"/"take me to work", etc.
Nafizur Sarai
03-29-2016 12:36 AM
iseeu1001
10-20-2015 05:37 PM
