I'm Back! Need New Stuff...
Old Jul 8, 2011 | 02:06 PM
  #81
jda123's Avatar
Dogmatic Dinosaur
Did you do your big 3?
Old Jul 8, 2011 | 02:14 PM
  #82
Trunk Monkey's Avatar
Coolest A-zine Member
Originally Posted by jda123
How is your ground on the amp? Be sure that you didn't ground it to a composite or alloy surface, but rather to steel or iron on the frame. Most noise issues are ground related. Some are related to the quality of the RCA cables or how they were ran. Did you use shielded RCAs?
Don't sweat noise in the sub if you remove the LOC - it will all get low passed out of the equation. If you go pre-amp on the sub, then use .1 to 1v. If you go post-amp, then 1 to 8v.
My initial ground wires were too short so I went to a shop to get a little bit of 4gauge and they just installed it for me. I didn't check to see where or how they did it but I will definitely check when I get home or this weekend. Thanks for the info
No on the big 3. I'm still not quite sure which wires need to be upgraded, etc. Plus I didn't have time before I left to do it
Old Jul 8, 2011 | 04:16 PM
  #83
I hate cars's Avatar
Originally Posted by Trunk Monkey
Wait..so the pre-amp, untouched sub signal is still crossed at 80hz? So the x-over is through our head unit? I would figure you would have full control of range if taking the pre-amp but I guess it'd have to be crossed before it reaches the factory amp then.
They do get plenty of output, even in this small sealed box. It does pretty damn well on rap as staying clean and loud. I'm still afraid to push them b/c I don't want to blow them or over do it. I'm not quite sure what kind of excursion I should be seeing or exactly what distortion sounds like instead of bass...ya know?
Why you say that?
By the way, ever heard of Argent Audio? They look like they make damn nice ported boxes for a reasonable price. Kerf ports, etc.
They will take 600w of clean power. As far as excursion, 16.5mm each way is xmax but they can be pushed to 25mm each way before any damage is done. 2" of excursion looks like a hell of a lot.
I do have to agree with Eggy, you might optimize the W6s before buying more subs. You could always cut the baffles for two 12s and if you don't like them, throw the SBP15s in there. The W6s sound very good IB. The only thing I would worry about is output, depending on how loud you like the really low bass. They will give you all the low end you could ever want, much more than the sealed but you have to watch excursion.
Old Jul 9, 2011 | 06:33 PM
  #84
Took the LOC out but only one sub is working. Wtf do I do?
EDIT: I got it..and I will not say how I did it lol. Freakin speaker wire came out when I was messing with the amp. Now..to test the no LOC subs!!
Old Jul 10, 2011 | 10:04 AM
  #85
Well I've had a little bit of time with the LOC removed and I can say that the low end does have more punch, digs lower, and has the ability to get louder. My SUB control on the headunit is at 0 or middle and I had to lower the gains from about half to a little under a 1/4 of the way! Works for me!! Thanks JDA
Might try to find the problem with the tweeter noise on start-up today but it's SOO hot. 110 yesterday and very humid
Old Jul 10, 2011 | 11:10 AM
  #86
jda123's Avatar
Dogmatic Dinosaur
You should not be able to hurt those W6 with only 1000W. Just make sure that it is not clipping or a dirty signal.
However, this should be well beyond what you can listen to for long without hurting your ears.
Start with the grounds. I used a stock ground location (with all of the gold rings, but I had to make it MUCH larger to accept some zero). Sand it down to shiny metal and attach it. Do your big 3 too... about 8 feet in 4 gauge and 6 ring connectors will get this done.
Old Jul 13, 2011 | 06:28 PM
  #87
eggyhustles's Avatar
Why you say that?
You haven't got them in the right box. Why ditch them?
Argent Audio makes good stuff for decent prices. That's where i sent tranceaddict to get the box for his xcon 12
Old Jul 18, 2011 | 04:46 PM
  #88
Question:
I've got the PPI art a600.2 hooked up and realized it doesn't have a x-over. I believe you have to run an external crossover or processor with it. I was freaking out b/c I thought I might have been running my RK6's rull range since I think I took the signal "pre-amp" and hasn't run through the factory amp to get the 80hz+ crossover or whatever it's at in the factory amp. BUT....since I'm using the passive x-over's, would that make it ok?? I had the x-over set at 80hz on my PDX. I've played a few rap songs that I know are in the 30-40hz range and I think I feel the mid's hitting but it could just be a different frequency in the song at the same time. Is this okay?? I just want to make sure I'm not running them full range
Old Jul 18, 2011 | 05:21 PM
  #89
Question:
Passives don't include a high pass so you're running a full range signal to them... My Infinity amp has no crossover either, I had to buy a crossover for it. You can have it if you want, I wasn't going to post it up for sale bacause it's only worth about $20.
FWIW, mine have always sounded cleaner and clearer the higher I set the high pass. That's one reason it's nice having subs that will play to 80hz and sound good.
Old Jul 18, 2011 | 05:25 PM
  #90
jda123's Avatar
Dogmatic Dinosaur
Those only respond from 65-20K. Unless the specs are wrong, there is not much of a chance that you are getting 30-40 to them. They might sound better, however, if you can keep them above 80 or 100.
Old Jul 18, 2011 | 05:36 PM
  #91
I ran the IDs full range sometimes and they hit lots of excursion when run full range even though freq response was like 60hz+. They didn't make any appreciable output down low but it muddied up the sound and gave some crazy excursion.
Old Jul 18, 2011 | 07:34 PM
  #92
Yeah that's what I figured. The tweeters get the x-over point but the mids play from the x-over point down to whatever it's given. Thank god I didn't play it loud or anything while I've had this in. I found the grounds that the shop did and they have both amps grounded to the same spot and its where something else is ground...right there near the ski pass under the carpet. I filed and sanded down the spot to bare metal and hooked it back up. Now I just need to re-try the PDX, etc w/o the ground loop isolater and see what happens. If it still happens...it's gotta be the RCA's.
How big of a ported box can fit in our trunks?? My ported box I built is too small for 2 12's so I'm going to sell it to hopefully fund another one or a sealed box....if I don't sell it all and go IB. I still don't think that 3 12's would fit IB but not sure. It'd just be more simple to run 2 15's also. Anyways, thanks for the help guys!! Hopefully I can get this amp noise issue worked out. One amp should be up for sale soon..if anyone is looking
Old Jul 26, 2011 | 02:29 PM
  #93
Alright, I've got a few more questions for you all!
1. I found a buyer and someone willing to trade for my Alpine PDX 4.100. The guy with the trade wants to trade an MB Quart Q4.150 (
http://www.sonicelectronix.com/item_...rt-Q4.150.html). This amp looks nice, powerful and looks like it could run active am I right?? If it's not that good of an amp, then I can sell it most likely tomorrow for $175.
2. HUUGE thanks for JDA for letting me try out the ID CXS62's and Audison!
They came in today and are sitting at home...I want to be off work to go play!!
3. I've been looking for boxes for the 12w6's and I've ran across a few. I know a few are saying go ported but at $200+ I just can't afford it right now. There's a box on craigslists that a guy has for 2 12" Type-R's (the new ones) and says it was custom built for those and has specs:
Looked like this one:
http://caraudiofactory.com/dual-tran...ted-p-126.html
12" dual sub box
Gross airspace: 1.85 cu. ft. per sub
Net airspace: 1.5 cu. ft. per sub
Port: 12" X 1 1/4" X 22"
Port volume: .29 cu.ft.
Tuning: F3= 27Hz, Ripple= 4.2dB, FB= 33Hz
3/4" Industrial MDF
Black industrial grade carpet
BUILT TO ALPINE SPECIFICATIONS for 2 12" Alpine Type R 12" subwoofers
38" W x 13.5" H x 15.75" D
Any good?? He said $75 and it's mine. I just don't want to get caught with either pre-fab or a box tuned to like 35 or 40hz or something.
-- For $70 to my door though, I thought about just doing this one which will give me 1.5ish per w6 (http://www.sonicelectronix.com/item_...-2.7-Gray.html)
4. My sub amp and component amp are both grounded to a factory ground spot right near the ski-pass. It's a small gold nut/bolt but I was wondering if that could be the reason for noise?? Do i need to have a separate spot for each amp....or can both amps be together but just not on a factory ground?
I unplugged the RCA's from the amp and I still got the start-up noise and hiss from the components so I don't think its the RCA's. Could it be this bad grounding spot or do I need to run the remote wire to the comp. amp first before the sub amp??
Old Jul 26, 2011 | 03:50 PM
  #94
Old Jul 26, 2011 | 04:29 PM
  #95
jda123's Avatar
Dogmatic Dinosaur
The amps can be ground to the same spot. Seriously... do your big 3.
Old Jul 26, 2011 | 05:05 PM
  #96
I am. Just taking out all the variables.
So should I pick up that q4.150? Looks nice and I'll be able to run active. BNIB too
Old Jul 26, 2011 | 05:37 PM
  #97
Unhooking speaker wires from amp works to remove noise...
Old Jul 27, 2011 | 12:12 AM
  #98
geekybiker's Avatar
Q is top of the line MBQ. Mentions of the mbq amps on diyma are generally positive though they aren't what they were before they got bought out. I've seen that amp for $160-170ish new before.
That help?
Old Jul 28, 2011 | 10:40 PM
  #99
Ok...I removed my amp, put electrical tape around all wires and RCA's. Sent it out today and the MB Q4.150 will be here Monday.
But..
I can still hear noise/static coming through my tweeters with nothing hooked up! Wtf
Old Jul 28, 2011 | 10:42 PM
  #100
That q is a decent amp
I would be looking at soundstream, though.
Reference, rubicon, and stealth are my favorite lines for budget amps.
Dude, stop with the prefabs already, lol. Save up for a box from argent.
Old Jul 28, 2011 | 10:56 PM
  #101
TranceAddict's Avatar
^ I placed an order almost a month ago from argent . He said it'll be a 3 week wait . Has a list so if you can wait it'll probably be worth it for the price . But im sure others could be faster t/a since he's backed up
Old Jul 28, 2011 | 10:58 PM
  #102
From what i know, it's him and someone else that does the boxes and he has dozens of orders.
Hard to crank out so many boxes when it's a 2 man team. They do top notch work at affordable prices, though.
Old Jul 28, 2011 | 11:08 PM
  #103
Hell I'd rather just build one or have one built for me for another $30-40 whenever I want. That small of a price difference is kinda null when it takes a month to get. Maybe he's related to the guys over at AE!
And it's kinda hard to really mess up a pre-fab sealed box. I already assumed I would re-go over all the edges to seal them effectively..just in case. For $70 to my door..hard to beat. Who knows though. Still deciding on what I'd like to do. Building a PC at the moment so this has taken a backseat. Those Argent boxes do look nice though
Old Jul 28, 2011 | 11:10 PM
  #104
At this juncture..I'm trying to figure out why the hell these tweeters are making static when they aren't even hooked up to an amp..
Old Jul 28, 2011 | 11:29 PM
  #105
^amen I hear ya ...but just get the right measurements and give it a shot ! If you dont want to wait
Old Jul 29, 2011 | 09:18 AM
  #106
jda123's Avatar
Dogmatic Dinosaur
How do you have them wired up? Do you mean that they are not wired to anything, or that they are wired to an amp without any input signal?
Which amp are you using?
Old Jul 29, 2011 | 09:22 AM
  #107
1. Removing either the positive or negative wire from the tweet removes the noise
2. Noise is there with car in anything but turned off
This is with NO AMP CONNECTED
so it's gotta be the x-over, twetter, or speaker wire interference..am I right?
Old Jul 29, 2011 | 09:23 AM
  #108
JDA- there is no amp on them in my car at the moment
Even when they were connected to an amp, they would still make static noise with the radio unit turned completely off (only nav. on)
The noise can be crackling to static to what sounds like the old radio noise you would get when changing stations. I'll see if I can find a good one on YouTube or something. I wouldn't think the speaker wire I bought would be bad or pick up a ton of interference.
Where do you guys run the SPEAKER WIRE for the drivers side mid/tweet? It seems most of us run it down the passenger side base molding..but then where? Mine is run behind the whole nav/radio/AC center unit, back near the firewall. Could that be a problem?? Near other stuff??
Old Jul 29, 2011 | 09:29 AM
  #109
jda123's Avatar
Dogmatic Dinosaur
You have the tweets on new wire that you ran for your install?
Old Jul 29, 2011 | 09:42 AM
  #110
Yeah. The tweeters came with like 1' of wire like they all do...but all the wiring is brand spanking new 14 or 16ga. (I think I used 14?). From rear amp (or where amp would be) to x-over..to mids...to tweeters is all new wire. Nothing stock was used.
Old Jul 29, 2011 | 09:52 AM
  #111
jda123's Avatar
Dogmatic Dinosaur
Dang. I guess eliminate the crossover and see if that helps.
You have the massives in still? Try one of the IDs and see if it does it.
Old Jul 29, 2011 | 09:56 AM
  #112
Yeah, removing the x-over was next on my list. Like an idiot I didn't run wires to the trunk for active so I'm buying all new speaker wire today at Monoprice so I can run active if I want. If not, I'll just hook up the x-overs in the trunk somewhere. Stupid on my part
I tried one of the CXS tweeters already, though it was when the amp was hooked up, but it still did it. So I'm assuming its not the tweeter(s).
Is 14ga. wire overkill?? Should I just buy 16? Also, is it bad to wire 2 strands of speaker wire together? So say I've got 14 coming from my mids and they go to the x-over in the kick-panel...can I just add new wire onto that existing wire or do i HAVE to run all new wire?
Old Jul 29, 2011 | 11:58 AM
  #113
Though this was cool. Sub box modeling for 1.5-1.6 sealed and ported for 2 12w6's
http://www.diymobileaudio.com/forum/...0-post209.html
Old Jul 29, 2011 | 12:04 PM
  #114
Vented
This actually looks just as good as sealed, with more output if you have a competent midbass to back it up.
And you do...
You should keep the massives and go active with them. With processing you can tame them to your liking. There are always anomalies you should eq down/out anyway. No set is ever perfect out the box.
Old Jul 29, 2011 | 01:22 PM
  #115
And you do...
I'll definitely try the RK6's active, no doubt. First, I need to run all new wiring to the trunk for active though. I know you can control a lot by going active but the RK6 tweeter is going to need some work to overcome the loudness. I've never really heard what "good" or acceptable midbass sounds like or should sound like so I'm kinda screwed there. There are a few guys over at DIYMA that swear by the CK6 mid, though they say they hated the RK6 mid as it was muddy and more for just sheer SPL-type setups.
Wish I could figure out this damn noise...
Old Jul 29, 2011 | 02:11 PM
  #116
jda123's Avatar
Dogmatic Dinosaur
Let us know if the new wires stop the noise. If not, then install a new RCA while you have the car apart - don't spend a fortune, but even a mid-grade stinger should be silent on a balanced signal.
Old Aug 2, 2011 | 01:46 PM
  #117
I was wondering a few things. I've already run 14ga. wiring from my mids through my doors and into the kick panel to the passive x-over. Same with tweeter. From dash down to the passive x-over. Is it okay if I just run new wire from the trunk all the way to the kick panel and connect it with the wire that's already ran for the mids/tweets? It won't be hard to do the tweeters but the mids are a pain in the ass to run through the door. Just crimp them together so I don't have to run a whole, solid run of new speaker wire.
Also, I used 14ga. wire (http://www.radioshack.com/product/in...rodsPerPage=60). Would I be okay to use 16ga. now since I'll have 4 wires and RCA's running down the passenger side for active haha. It's already tight in there! I figure it might not be smart to run 16ga. and then connect it with 14ga. and have about 4-5ft of 14ga. to the mids (and tweets if its ok to leave them like this) but who knows. Thanks man
Old Aug 2, 2011 | 01:53 PM
  #118
16ga is more than adequate. Heck, I even have it running my subs right now.
Old Aug 2, 2011 | 01:58 PM
  #119
Thanks IHC and JDA. I'll order up some 16ga. and I need to check to see what my subs have as far as their gauge. Might not be adequate now that I think about it.
Now onto....miniDSP or Fosgate BLD to likely fix my noise issues...
BIG 3 coming soon JDA! haha. Glad you said that as I completely forgot about doing it. I'm sure that will raise my voltage levels a ton
Old Aug 2, 2011 | 02:15 PM
  #120
jda123's Avatar
Dogmatic Dinosaur
Use that Audison amp that I sent you while you are figuring all of that stuff out and waiting for it to come in. It is supposed to be able to take a balanced diff input through the low level (RCA).
