If you've modded the lights around the nav console
A-spec steering wheel ftw
..............please post a pick, and a how to? ive searched a bunch of different terms and end up seeing a bunch of posts on the courtesy lights, trunk lights, etc etc...
my car is off warranty now, and the lights behind the buttons are dim, i want to swap them out for LEDs, blue LEDS, or if that's not possible i want a bright light and just overlay it with a blue film (as stillhere suggested).
can someone please direct me to the right link? or just show me how it's done?
if you dont want to post a link or tell me how it's done at least please post a pic of it
thanks!
thanks!
ive done it on a ton of cars just not on the tl.....its very very tedious depending on the setup....on the tl I know some buttons are illuminated by actualy mini bulbs that are twisted into the switch other have it soldered on to a board and are LEDs.....again its super tedious... unless u have experience soldering with a magnifying glass or a super small mini tip like needle to solder i wouldnt do it.
ahh well done there u go...... best bet with the bulbs is get a rubber cover for them to illuminated the color u want because they dont make ones that are aftermarket for that...or another thing i was thinking about was breaking the bulbs soldering the conductive ends to the led platform (because LEDs that size are super small and square) and then gluing it down to the original base of the bulbs there s afew ways to go about it and now im gonna go play with it lmao!
let me know how it goes!
hmm...this is depressing, i was really hoping to be able to milk out the whole BLUE theme on the buttons.
If you search on the forum you'll find some DIY to remove all console parts and that way you could get to replace the LED....
Taking me 5 minutes now !!! :P
EDIT: I'll have to remove my dash for some minor install tonight I'll do a DIY video for the GARAGE cause to many people are asking HOW TO REMOVE THE DASH!!
Vmt
Vmt
Mind posting a link? I can only find two threads about "console lights" -- this one and another thread which doesn't have a DIY.
I think the bigger issue, based on what I've read, is that the LEDs are soldered onto a board and not just ones you can pull out and replace. Correct me if I'm wrong because I'd really like to fix this problem.
Originally Posted by erick3
from what i know, they're all small leds. crazy attempt to swap them = epic failure
maybe for you eric lol
but i dont think it should be a hard swap... some 2G members replaced to LEDs on there HU, and Speedo's...
sockr1
Oct 1, 2015 01:31 AM
Rocktman1
Sep 19, 2015 05:58 PM
