If you had $1000-$1200 to spend on an amp, sub, and front stage, what would you get?
baller on a budget, b!tch
Contemplating doing a conservative system upgrade in my TL. I don't want anything over the top, I just want a decent upgrade to what is the crappy stock system.
I already have an Isimple installed on the factory deck. Another thing that is important to me is trunk space. I like to carry around miscelaneous parts and sports gear back there for an unknown reason. I think there is also a pack of stick on moustahces from the last cinqo de mayo. Anyways, throw your ideas at me if you have a minute. TIA
Here's what i came up with.
Rockford 360.2 $250-300
Image dynamics cxs 2 ohm $309
http://www.woofersetc.com/p-7173-cxs...nt-system.aspx
You can make an offer on sonic for around 200ish and they might accept
http://www.sonicelectronix.com/item_...v.2-2-ohm.html
Massive nx2
http://www.sonicelectronix.com/item_...Audio-NX2.html
You can make an offer for like 115-125. They might accept.
Couple options for subs.
1. 1 Tc Epic 10 $188
http://www.parts-express.com/pe/show...number=293-656
This needs 500 watts @ 1 or 4 ohms
This will work well in 1 cube sealed.
2. 2 Alpine type r 8's $200
These work well in .5 each sealed..so 1 cube sealed for the pair just like option 1. 3 will be great but probably no budget for it.
700@ 2 ohms for 2 or 1000 @ 1 ohm for 3
3. 3 Jbl Gto 8's $180(for all 3)
http://cgi.ebay.com/JBL-GTO804-CAR-A...ht_2544wt_1139
These work well in .35 sealed, so 1.05 sealed for the trio.
600 watts @ 1 ohm
4. Image Dynamics idq 10 $239
http://www.woofersetc.com/p-5807-idq...subwoofer.aspx
600 watts @ 2 ohm
These work VERY well in 1.20 cubic feet sealed. This will be the biggest box and most expensive, but will sound the best out of the 4.
Amp for sub will depend on which option you choose.
Massive nx2
600 watts @ 1 ohm
600 watts @ 2 ohm
AcRightLINY (09-29-2011)
Thanks alot for the help Eggy. I was thinking something along the lines of a single 10" setup over multiple sub setups. I like the idea of getting one, decent multi channel amp for both the front stage and the sub.
Coolest A-zine Member
Those little Alpine 8's are getting a ton of love on DIYMA. Might try a few of those in a small ported/sealed box if you're looking to save space.
With that budget, you have plenty of options. Definitely don't forget deadener though or all that money is wasted basically
handsom-hustla
11-13-2015 05:04 PM
Pegon95
09-15-2015 01:54 PM
