I need help?
Old Aug 12, 2011 | 09:29 AM
ryder21's Avatar
I need help?
I have a 2006 Acura Tl 6 speed. With navi I loaded my cd player and now its jammed. The cds wont eject and they wont play I'm not sure what to do next. I pulled the fuses but the radio still works. I disconnected the battery but after putting in the code it still wont play. What should I do?
Old Aug 12, 2011 | 09:32 AM
your cd player took achit.
Old Aug 12, 2011 | 09:37 AM
KN_TL's Avatar
You're probably going to remove the headunit and disassemble it to get your discs out.
Old Aug 12, 2011 | 09:51 AM
garrett's Avatar
unfortunately this is most likely the only option now...
Old Aug 12, 2011 | 10:01 AM
Trunk Monkey's Avatar
Coolest A-zine Member
Time for an Isimple
Old Aug 12, 2011 | 10:03 AM
i wouldnt worry about the cd.
i would change out the cd player, or go the isimple route
Old Aug 12, 2011 | 10:25 AM
imj0257's Avatar
Q('.')=O
^ Is that Jefford?
Have you asked the dealer about it? First over the phone ask them what it could be.. but I wouldn't be surprised if they tell you that you need to bring it in for them to look at
Old Aug 12, 2011 | 10:27 AM
lulz at jefford.
Old Aug 12, 2011 | 11:49 AM
a massive ipod will likely sound fine to you if you weren't using DVD-A for FLAC/WAV. It'll show up on the nav too. Consider this your lucky day!...no?...k
