i need the 2 bin files to hack 3.40c please help
i have look everywhere and can't find it. if anyone would be so kind to send me the bin files
BN2HHMLD.BIN
BNHH401A.BIN
I really don't mind what kind of start up wallpaper you have but i really need that it has the ok hack, trip computer and ac hack. just the 2 files ready to burn on a cd.
my email is eduardmc@gmail.com and is possible to email it to me.
i tried the one on this link from user name "acuratl44"
http://www.acura-tsx.com/forums/showthread.php?t=610283
but i have follow the instruction and burn already 6 cd and 2 dvd (using different softwares) i get the message "check cd files" so i believe is something incomparable with the files.
again, this would be really helpful to me. thanx
BN2HHMLD.BIN
BNHH401A.BIN
ok this one that you send me are modded straight to burn on a cd, or i have to modify them myself. also what the 404A.bin do. please if this are stock version i really need the modify version just to burn on a cd and have all the mod ready. thanx for sending me the files and your fast service, if you need any small donations let me know, i'll be willing to do so cause, i do not want you to feel obligated on all this.
Chapter Leader (NY/NJ)
dont worry about it. This is AcuraZine. its what we are here for. i'll send you modded versions later on. what seems to be your problem with the mod? are you working Dumpnavi correctly? i think the 404 is for removal of the nag screen or to have AC on the display and other things as well. i forgot its been a while.
File 404A is for and i quote---
A note from AngryDad:
When you do the trip computer patch, you might as well benefit from replacing diag.exe from the 401a bin with diag.exe from the 404a bin. It enables trip computer screen in diag menu (where you can log data to the card if interested). Holding "Menu" for 5 sec on that screen, gets you to "Trip Computer calibration" menu.
so i guess i already added it to the 401a. guess, you dont need it.
one side note, all the disk were done in windows 7 64bit (which i think it should not matter) also i don't know if it matter but martin install my navigation and i'm not sure if buy using different parts or dvd drives. but i'll let you know if i find the problem. thanx for everything
just do a drag and drop of all of the bin files...there is 8 in all iirc...
on vista or windows 7...when u insert a blank cd there is a more options drop down...drop it down and make sure that you select "MASTER CD"...not live CD...
give that a shot..
-Jason
give that a shot..
-Jason
i'll your method and also try this. i will take the dvd out and copy every content to my hardrive, replace the 2 bins files for the hack files and make a dual layer dvd o see if it works, i know i might waste a DL dvd but is worth the effort. also i might think that because martin install my navi using his custom made wire harness some of the conection my be missing, cause after going into dignostic menu (holding, guide, menu and cancel) were i can select trip computer from hiding menu, the button is grade out, like is it not connected or something. also to cheCk the navi i might think that i would get everything in green but thing like ac, trip computer etc are in RED.
u need the 8 files only...
on a cd...
only 140mb max neede...
don't waste a dvd!!
-Jason
found out what my problem was but very weird, even though i'm using the 3.40c disk, it did not take the file BNHH401A.BIN. it never loaded, but i found this file that people use on 3.60 and up disk the BN2HH12C.BIN and this is the only file that loads up in my navi. finally hacked it with my own picture, very happy with it. thank you all
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
