How to wire myron and davis with battery?
hey guys, i just got myron and davis dvd player. i would like to wire it to a motorcycle battery (12v 8ah) so i can test it before i install it in the car. it has a battery lead, acc, and ground. do i just put the battery and acc together in the positive terminal and ground to negative of battery? also when i wire it to the car the acc goes to fuse #32, where do i wire the battery lead is there another spare fuse slot i can use that can go straight to battery?
you can basically find any power source that is a constant 12v for the power wire and connect the acc to when you want the dvd player to turn on.
i have a myron and davis dvd player in my car, its fuse tapped into the acc socket.
MetalGearTypeS
08-29-2016 08:28 PM
SUPRMN84
10-07-2015 09:46 PM
