How to turn off the Nav screen..
Old 02-08-2017 | 03:36 PM
SkyDiv3r14's Avatar
07 TL-S. If I hit the navigation button, it will always stay lit and show the nav or audio screen until I restart the car. If I don't use the audio button for 30 seconds the screen will go black. How do I make the navigation screen go black after I'm done using it?
Old 02-08-2017 | 03:37 PM
you can't
Don't press the okay button on the navigation nag screen. If you need to change something on the screen audio-wise, you can press audio and it will pop up on the screen and then turn back off. It's the Navi more than anything else.
Old 02-08-2017 | 03:53 PM
SkyDiv3r14's Avatar
you can't
Well that's depressing haha. Thanks for the quick reply!
Old 02-08-2017 | 04:19 PM
sockr1's Avatar
you can turn your screen off manually whenever you want. i forget what button exactly but i think push setup button and then there is a "display" setting...push "off"
i turned it off fairly often if i had a long night drive and didn't need the screen
Old 02-08-2017 | 04:25 PM
I was talking out of my ass apparently.. soryr OP
https://acurazine.com/forums/newrepl...ply&p=13376334
You sure can ! Thanks for the correction sockr!!
OP when you run into an issue you need resolution, check out google and search your issue and use "site:acurazine.com" at the end and you'll find many threads include the one linked above. here is what it looks like:
https://www.google.com/search?q=3g+t...hrome&ie=UTF-8
Old 02-08-2017 | 05:07 PM
SkyDiv3r14's Avatar
I literally searched "turn off nav screen" on this website and bunch of random stuff came up hahaha. I'll be sure to use Google next time.
Alas! A solution! Thanks guys.
Old 02-08-2017 | 05:09 PM
yeah.. unfortunately our search on this website is sort of a piece of crap... but it's being worked on..
You can put in your input here: https://acurazine.com/forums/acurazi...engine-954549/
Old 02-08-2017 | 05:14 PM
SkyDiv3r14's Avatar
"Being worked on" 😂😂. I was on clubintegra for 8 years and its search sucked badly the whole time..
+1 for Google I guess 😂
Old 02-08-2017 | 05:18 PM
Yeah I found a solution for the tech team, they're willing to change it provided there is enough 'demand'
SO GO DEMAND IT!
Old 02-25-2017 | 07:36 PM
mugened's Avatar
6th Gear
Thanks! Been wondering how to do this.
Old 03-22-2017 | 09:14 AM
Le7316's Avatar
Now, is there anyway you can dimmer your screen at night ? I am only talking about the screen not the cluster . Man, that screen is BRIGHT at night and thought the screen is automatically switch to "night mode " or maybe im missing something here ? Yes , the car is still new to me....just bought it recently.
Old 03-22-2017 | 09:51 AM
it does.. if you made sure to set the setting to "Auto"
Old 03-22-2017 | 11:54 AM
truonghthe's Avatar
if you too lazy to click the link then follow these step.
press setup ----> look for screen setup where it say "auto, day, night, and off. Press "off" on the Navi to turn the screen off.
In order for Navi screen goes into night mode automatically your cluster brightest setting must be highest NOT "Max" where the cluster light will dim when your headlight is on. If your brightness setting on "Max" like me then you will have to manually put it in night mode and manually switching it back to day mode.
Dam thoiboi is messing up here.....
Old 03-22-2017 | 01:05 PM
Old 03-22-2017 | 01:34 PM
Le7316's Avatar
Thumbs up
Got it. Mucho gracias
