How to retrieve voicemail with Razr v3
I have searched the threads and still cannot find a way to retrieve the voicemails on my Razr v3 through the HFL. When I dial my complete cell phone number or the *86 number I always get that long ring tone.
Does anyone have any ideas?
Hi Guys,
Here is how I did it. I have ATT so when I press and hold #1 I go directly to voicemail. After you call the voicemail look in the recent dialed calls. In my case it gives me the number called for the voicemail. I got the number and then programmed it into the HFL. So now when I have voicemail I just tell the HFL "Voicemail" and go straight to it. I still have to use the phone to erase, skip or save messages.
If anyone else knows a better way please let me know.
By the way I also have the Razr as well as the L6.
That sounds about right anasjutl. It should work for most, if not all, compatible phones.
You also have the ability to save your password with the number. Check out the 3G TL Audio & Electronics FAQ on how to use special characters and the "Send" command.
Sorry about that. I should have made myself more clear.
Instead of saving just the voicemail number in the phonebook, you can also append the password to the end of the saved number, ie 1231231234pp12345#. The p will cause the system to add a pause before the next input (two ps creates a longer pause). This, of course, depends on how your cell phone carrier handles voicemail passwords (if they even require it).
Here are two threads on this topic:
