Homelink opening multiple garages on same button
Old Dec 29, 2011 | 12:20 PM
vagabondma's Avatar
3rd Gear
I'm trying to program homelink on a 2005 TL. The first button had been programmed to open another garage at our house. I cleared the memory per the manual, and retrained it to the other garage. But now when I press the button it opens both garages. The garages are on two completely different frequencies. Obviously the memory isn't clearing completely, but I don't understand how homelink can store 2 codes on the same button. Would anyone have any ideas how to fix this?
Old Dec 29, 2011 | 01:43 PM
KN_TL's Avatar
It depends on the opener. On mine, the opener learns the remote, not the other way around.
What kind of openers are they?
Old Dec 29, 2011 | 03:26 PM
vagabondma's Avatar
3rd Gear
Both garage motors are from liftmaster.
To clarify, the homelink button inside the car has no problem learning the code for the garage motor. But it seems to have kept the other garage code in the memory as well, so now the homelink button opens both garages.
Old Dec 30, 2011 | 02:40 AM
ohsixMTee's Avatar
Early Shifter
I would clear the memory and reprogram your openers to separate buttons.
Old Dec 30, 2011 | 08:25 AM
vagabondma's Avatar
3rd Gear
I already tried clearing the memory, that's the issue. No matter how many times I clear it, it always remembers both garage doors.
Old Dec 30, 2011 | 09:22 AM
KN_TL's Avatar
Are these older openers with dip switches or the newer kind that learns?
Old Dec 30, 2011 | 01:53 PM
AdamNJ's Avatar
Make MyTL Great Again
I haven't touched my settings in years, but if I recall correctly, when you try to reprogram your homelink buttons, don't you also have to go to the opener itself and press the learn button?
If so, then I think what you did is:
button 1 was programmed to door B
button 2 was programmed to door A
You wanted to make button 1 control door A, so you pressed the learn button on opener A, then went to you car and held down button 1. So then you just programmed your opener to open at the frequency/code for door B. Both door open with the code for B.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
