Homelink
Homelink
Has anyone had any problems with it..... I was in FL last week and it wouldnt work on my house garage opener like it just died out then when i got back tO NY and put my subs in pounded the crap out of them and then it started working again......am i retarded or has this happened to anyone b4?
If you are saying that when you left NYC and it didn't work and when you came back it worked in NYC, it could be a loose wire.
Depending on where you were in Florida and what was nearby, perhaps something could be interfering (assuming it was set up properly). There have been stories in the news here about people living near the Marine Corps base in Quantico whose garage door openers stopped working because the Marines started using the same frequency for something or other, and under FCC rules a garage door opener must accept any interference. Stinks, huh?
My Homelink is sometimes slow to work when I back out of the garage into the morning. Most days it works fine, but some days I have to pull forward closer to the garage door before the door will go down. Very strange, and no pattern to when it happens, and I don't live near the Marine Corps base.
nono no programmed link in NY only in FL and when i would press it nothing would blink i took the whole junk apart and still...nothing..... I get back to NY I go to hit the light to turn it on and I miss n hit the link and it works..... I was about to rip it out lol
oh, so you mean when you were in FL, the enitre unit didn't work, like no blinking light or anything. But when you got to NYC, it started working again. Odd, I would have the dealer check out the harnesses for shorts or a bad ground connection. Also i would have them check out the unit itself.
Chonny
06-07-2007 03:45 PM
AcuraTLSFan
2G CL Frequently Asked Questions
01-19-2004 10:19 AM
