Hidden navi menu warning!
Old Aug 2, 2004 | 01:20 PM
emde's Avatar
So, I read the MAP-MENU-CANCEL hidden menu thread. Lots of menus in there, some cool stuff. Well, I kept digging deeper and accidently hit a "load from disc" under the version menu (IIRC). Long story short, this loads the default ROM image from the DVD and re-flashes your Navi system!
This new image has two different things I have found so far:
* Under info (where calc and calendar are) there is a new menu option for trip computer. This shows current MPG and other various stats on your trip. Pretty cool. However...
* The Volume control for the subwoofer is gone!
* Last but not least, the usual Acura logo displayed while your Navi boots up, turns to a Honda logo!
I went to the dealer and have an appt. to reload the firmware on the Navi, hopefully they can fix it quickly. Just a warning to all those who love to tinker with the hidden menus!
Old Aug 2, 2004 | 03:25 PM
Dave04TL's Avatar
What version of the DVD do you have? Just wondering if the "G" version is the latest/greatest and if that would make a difference. Can you post screen shots?
Old Aug 2, 2004 | 03:39 PM
fuque's Avatar
Sounds like you loaded the firmware for the Accord instead of the TL firmware. The TL firmware, as well as several other versions, is there on your DVD - perhaps if you try again you can re-load the correct firmware file...
Old Aug 2, 2004 | 03:59 PM
emde's Avatar
After pressing discload, there is no option to select a firmware file to load
I will check the version of the DVD after work.
Old Aug 2, 2004 | 04:15 PM
rets's Avatar
Moderator Alumnus
Someone burned Accord's Navi DVD to work with TL and did make Trip computer work, too.
It's interesting to see the screen change from Acura to Honda by simply loading your original TL's Navi DVD. I did this before with my early version DVD (I got my car in Oct.), and it seemed that nothing happened.
Since you have to check the version of DVD, do you know your last 6 digit VIN (53xxxx)?
Old Aug 2, 2004 | 05:02 PM
mdanese's Avatar
Anyone know where more detail would be on this topic. I have a TL, but my wife has the Pilot with NAV. It would be great if I could enable the trip computer -- that is the one thing we lost from the Highlander when we bought the Pilot.
Old Aug 2, 2004 | 10:43 PM
emde's Avatar
BTW, if you go to the diags, select version, and press menu for 3 seconds you can see what the boot file is. Mine says BN2HH12C.BIN.
Old Aug 4, 2004 | 02:50 PM
emde's Avatar
Yesterday the dealer fixed my navi. They had to pull the ECU from the navigtion dvd rom unit in the trunk out and put it back in. I guess this resets it to facotry defaults. Seems like a battery disconnect for a few minutes would do the same.
Old Aug 4, 2004 | 11:11 PM
żGotJazz?'s Avatar
Cesspool of Knowledge
I've also heard that you lose the "Send" command from the Navi to the HFL when you load the Accord Navi system. I think there's also some Voice Recognition stuff that you can lose as well.
In a word: Don't do it! (OK, that's three words.)
Old Aug 5, 2004 | 12:23 AM
emde's Avatar
My HFL worked fine while it was a "Honda".
ITSJESTER
17
Dec 6, 2018 02:29 AM
lanechanger
Oct 13, 2015 10:56 AM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
TL14
Sep 24, 2015 04:37 PM
