HFL is in use constantly. Cannot disengage!
Old Mar 21, 2005 | 09:46 AM
CYBERTIGER 718's Avatar
I got a few back-to-back calls Saturday night. After which the HFL just froze in the "IN USE" mode. I cannot play the radio or anything. It stays on all night and today is Monday. I have the Nokia 6820 and I've been using the phone with this system since I purchased the car without a problem. Even with the phone away from the car, and the car being off all night I'm still having this problem. I've called my service advisor and he didn't know what to do. I called the dedicated HFL service number and they told me to take it to the dealer and advised me not to disconnect the battery. Does anyone know what I can do?
Edit by MOD cTLgo: reduced font size
Old Mar 21, 2005 | 09:47 AM
Rets where r u?
Rets I need your expertise on this one. Where are you?
Old Mar 21, 2005 | 10:01 AM
rets's Avatar
Moderator Alumnus
What happens after you turn off the engine? Will it disconnect?
While it's frozen, can you turn off your mobile phone? Will MID get back to the normal screen?
Old Mar 21, 2005 | 10:09 AM
No
When I turn off the engine nothing happens. "IN USE" on in the MID ALL NITE!
Old Mar 21, 2005 | 10:10 AM
The phone works fine.
The phone works normally with or without bluetooth being on.
Old Mar 21, 2005 | 10:14 AM
rets's Avatar
Moderator Alumnus
Sounds like HFL system totally screws up. I heard some ppl replaced their HFL module, not sure whether or not your issue is relevant. May I know who your dealer is? Thanks.
Old Mar 21, 2005 | 10:31 AM
ChuckDu's Avatar
I would first try disconnecting the negative battery terminal for 15 minutes or so. Be sure to have your radio/navigation codes available.
If that doesn't clear up your problem, a trip to the dealer seems in order.
Old Mar 21, 2005 | 10:44 AM
rets's Avatar
Moderator Alumnus
Thanks.
Btw,
https://acurazine.com/forums/showpos...93&postcount=7
Originally Posted by tazal
Just as an FYI, I had this happen to me and found little help online. I didn't want to pull the whole battery...
I was surprised when the service manual indicated that the interior light fuse had a lead to the HFL control unit. It almost made me wonder if they didn't design it that way on purpose so you can force a reboot of the HFL system without disconnecting battery or having to reset the radio, etc, etc. Dumb luck or planning to deal with a known failure I don't know but I was happy when I pulled fuse #6 of the interior fuse box, replaced it and found everything back to normal.
I doubt anyone in this thread cares any more but I wanted to throw it out here for the next person that googles for it.
A few key word for the bots:
HFL lockup HandsFreeLink disconnect battery pull fuse "Phone in use" stuck
P.S. If you find a problem like this and figure out a workaround please provide details so others know better how to deal with it. Just saying "I yanked a bunch of fuses and finally found the right one" doesn't do anyone any good.
Old Mar 21, 2005 | 04:09 PM
cM3go's Avatar
I had this issue and disconnected the battery terminal... I actually reconnected it 10-15 seconds later... the problem cleared and I didn't have to enter any codes for the radio or navi.
Old Nov 19, 2007 | 08:47 PM
parman03's Avatar
First try to delete the phone. Look in your owners manual under hfl. About page 60? then follow the directions on deleting the phone. Once deleted, try a pair the phone again. If you still are having problems vistit the Acura/honda hfl website at www.handsfreelink.com for further info. I hope this helps.
knight rider
Mar 4, 2016 08:59 AM
spoiler900
Oct 10, 2015 06:48 PM
phillyguerrilla
Sep 26, 2015 11:27 AM
rmittal
1/2G MDX (2001-2013)
Sep 19, 2015 08:41 PM
Markbby06
Sep 17, 2015 02:30 PM
