HFL shut off
Old Dec 26, 2014 | 11:17 AM
ROSSARONIE's Avatar
HFL shut off
Does anyone know how I can shut off the HFL ? It currently does not work on my 2007 tl and is draining my battery. I know this because of a frost in the morning, I went outside to see my car covered in frost except a melted patch right above my rearview mirror. I am going to try to either replace it, or try a capacitor replacement that I've read about, but for the meantime I'd like to be able to start my car after it sits for a night.
Looking for a quick fix, and thenwhen I have the time fix the issue entirely.
Old Dec 26, 2014 | 11:30 AM
anx1300c's Avatar
Just unplug it. I took mine right out. It only takes a couple minutes. It's behind the lights behind the rearview mirror.
Old Dec 26, 2014 | 12:00 PM
vietxquangstah's Avatar
There is no quick fix short of actually unplugging the unit which requires you to disassemble part of the housing which it sits in.
Old Dec 26, 2014 | 12:20 PM
ROSSARONIE's Avatar
Thank you, this won't affect anything else will it? I started looking for a fuse, but unplugging this seems simple.
I've seen a 3 part video on how to replace the HFL. Pop off the faceplate, and a couple acrew to remove it.
Old Dec 26, 2014 | 02:07 PM
Will Y.'s Avatar
Registered but harmless
Originally Posted by ROSSARONIE
...this won't affect anything else will it? I started looking for a fuse, but unplugging this seems simple.
Yes, unplug/remove the HFL; do not remove the fuse for it.
The fuse is common with some other minor controls or interior lighting, IIRC.
The process is well-described with photos in the thread at: https://acurazine.com/forums/audio-b...-06-tl-843512/
That thread also describes the board-baking repair if you are so inclined.
Welcome to AZ.
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
rockyboy
Sep 29, 2015 12:05 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
prbori
Sep 27, 2015 01:37 AM
phillyguerrilla
Sep 26, 2015 11:27 AM
