HFL install
Old Nov 9, 2015 | 03:41 PM
ksr69's Avatar
HFL install
Do I need to disconnect the battery before installing a new HFL in my 08 Acura TL w/Navigation? I am hoping to avoid having to redo the radio and navigation startup.
Old Nov 9, 2015 | 04:50 PM
guitarplayer16's Avatar
its a good idea to
Old Nov 9, 2015 | 08:33 PM
paperboy42190's Avatar
recommended to always disconnect the battery, but with a careful and correct install, nothing will mess up if you dont disconnect the battery. definitely keep the key out though, so the hfl isn't trying to start up as you plug it in
Old Nov 9, 2015 | 10:48 PM
truonghthe's Avatar
I replace mine without disconnect the battery, just make sure you don't put the key in ignition.
Old Nov 11, 2015 | 06:31 PM
ksr69's Avatar
I installed the HFL without disconnecting the battery following the advice of not having the key in the ignition. Completed task without any mishaps. All works great. Can't believe how easy this install was. Thanks.
Old Nov 11, 2015 | 07:24 PM
truonghthe's Avatar
you just save $850 from what dealer wanted for the repair.
ottoman101
44
Mar 19, 2022 09:14 PM
dezymond
Apr 11, 2016 09:00 PM
illistik
Dec 27, 2015 11:41 PM
Keazo M Thomas
Nov 14, 2015 07:22 PM
Muratbozy1
Nov 3, 2015 12:05 AM
