HFL "booting up" question
I have searched and found that my HFL module has most likely gone bad as it is stuck "booting up". Recently when my car sits for a few days without being started I have to jump it off. I know that this is probably caused by the HFL. I have read that it doesnt shut off when its like this and draws a small amount of current that is draining my battery just enough after a few days.
my question is, can I just dis connect the HFL module without it messing up anything else like the display, remote entry , etc...???
OP this post was edited to comply with the rules for buying and selling in this site.
If you want to post a Want To Buy thread, please do so in the Black Market forum which is found in the Off Topic section.
Dogmatic Dinosaur
It is in the overhead console by the map lights. Take the sunroof switch out with a feeler gauge, then pull the map light out with your fingers. The housing is held on with 4 8mm bolts.
2006 Acura TL
^^ yeah i agree, i had the same problem and i disconnected mine and it solved my battery problem. went to the acurea dealer and the service representative told me to disconnect it
Does the diagram above work for the 07 type S as well? Cause my BT is acting up as well and my battery is starting to die. For the past 2 days my car has had some trouble starting up. It sounds like it's dying and then fires up. How do I save my battery?
2006 Acura TL
yes it should
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
