Hfl
Old Jul 7, 2011 | 08:24 PM
Rafael74's Avatar
6th Gear
Hfl
Hi,
I've recently bought Acura TL 2006 with Navi.
I'am unable to pair my phone to HFL,because talk button doesn't work. When I push it,no beep signal comes.
Any idea???
Old Jul 7, 2011 | 10:26 PM
Will Y.'s Avatar
Registered but harmless
If you're using the HFL buttons facing the driver on the steering wheel, it may be a dead HFL.
Go to the MID and check the status of "HandsFreeLink"-- if it says "booting up," the HFL is likely dead.
You might try disconnecting the battery for a half hour to see if that unlocks/resets the HFL-- just make sure you have the Navi and Radio codes handy to reactivate them after reconnecting the battery.
If you're trying to use the buttons on the back side of the steering wheel for the HFL, those are for Navi voice commands.
Welcome to AZ, and G/L.
Old Jul 8, 2011 | 11:19 AM
LoveMyTL-S's Avatar
Congrats and welcome to AZ! You may want to register her at www.myacura.com. Save your Navi and radio codes there for safe keeping.
Old Jul 8, 2011 | 11:58 AM
flyromeo3's Avatar
was this a private sale?
If not, take it back to dealer and have them fix it.
Old Jul 8, 2011 | 12:15 PM
Mafyoso's Avatar
Balling in the...
^ Thats would be my idea to. Shit sucks when u buy something and find out something is defected in it FML
Old Jul 8, 2011 | 12:22 PM
Rafael74's Avatar
6th Gear
Hi Will,
Thanks for your reply.
Navi Voice commands works perfect.
When I go to MID HFL part and push select/reset button then it shows up booting up.
I have navi and radio codes with me.
Old Jul 11, 2011 | 12:03 PM
Rafael74's Avatar
6th Gear
Is 2008 TL HFl will work in 2006 tl??
Old Jul 11, 2011 | 12:07 PM
ttribe's Avatar
Originally Posted by Rafael74
Hi Will,
If it shows "booting up" and never changes from that, the module is dead. Happened to mine.
Old Jul 11, 2011 | 12:24 PM
GrwnUpRcer's Avatar
mine is toast too. worked great for a week when i bought it now its 'booting up'. you'll find 1000 other poeple with the same problem. def sucks
Old Jul 11, 2011 | 12:29 PM
ttribe's Avatar
I don't know why it wouldn't. I don't think anything changed on the HFL between those years.
Old Jul 11, 2011 | 01:11 PM
geekybiker's Avatar
The gauges changed. Don't know if that means the out for the display changed too.
Old Jul 11, 2011 | 04:53 PM
Rafael74's Avatar
6th Gear
I can get 2008 TL HFL for free. But don't know if it will work on my 2006.
Any ideas??
Old Jul 11, 2011 | 04:56 PM
Rafael74's Avatar
6th Gear
Today "booting up" is disappeared and HFL asking for code??
Old Jul 11, 2011 | 08:33 PM
Will Y.'s Avatar
Give it a code to see if you can unlock it.
The HFL can be set up with a password code.
Try the default codes suggested in the manual: 0-0-0-0 or 1-2-3-4, something like that.
mada51589
Jan 9, 2025 04:40 PM
phillyguerrilla
Sep 26, 2015 11:27 AM
rmittal
1/2G MDX (2001-2013)
Sep 19, 2015 08:41 PM
cali boy 91
Sep 19, 2015 01:57 PM
Markbby06
Sep 17, 2015 02:30 PM
