Help, Trying to Pair Phone To HFL
I just got a LG350. Yes I know its in testing, but I did try it with phones that should work. The furthest I get in the process is when I get the command "Phone setup options are status, pair, edit, delete, list."
After I say "Pair" I get nothing. I've tried following that by giving a four digit code. Again, nothing. What am I doing wrong?
Do you press the button before you say "PAIR"?
You need to press the button before every command you issue. If you're getting stuck there it's nothing to do with your phone.
You might need to slow down and read your owners manual.
Press the button? The instructions only mention voice commands. There is no mention of pushing a botton after ever command. Are you saying I need to push the talk button after I say "Pair" and then after I give the four digits?
you also need to make sure that the phone is in discovery mode. so you say "pair", and then give the code, and the phone itself needs to be in the mode where it looks for bluetooth devices.
On my motorola i go to the bluetooth headset menu item and press "look for devices"
also the car lists the options, you press the phone button by the steering wheel and answer "pair"
Like I said. I can get to phone setup no problem. When the car says "Phone setup options are status, pair, edit, delete, list." is where I'm having problems. Like the instructions say, I tell it "Pair". According to the instructions its supposed to say "The pairing process requires operation of your mobile phone......" I never get this message. Am I supposed to hit a the talk button after I say "Pair"?
mlody
12-04-2019 02:11 PM
ExcelerateRep
10-14-2015 08:20 AM
phillyguerrilla
09-26-2015 11:27 AM
