help with price
Old Apr 29, 2009 | 11:02 PM
ac-attack's Avatar
help with price
hey guys ima about to install components in my back rear deck but hears the thing i already have components up front with a alpine pdx 4 channel amp only using two and its all set up already but now im ready to throw some in the back and im kinda confused on how much the shop would charge me i believe he said a hundred just to throw in the back components is this to much considered the amp is already installed
Old Apr 29, 2009 | 11:20 PM
fade2blk's Avatar
No not at all, considering all the steps needs to go through on TL.
remove the back seat (side).
remove side pillars.
remove rear deck
remove rear speakers
run new speaker wire or tap into existing one.
build a plate for components or modify rear deck for the tweeter placement
reinstall everything in reverse order.
sounds like it is not a big deal and it is not but it is time consuming.
note: if rear deck is not reinstalled correctly. rattles may apear.
hope this helps.
Old Apr 30, 2009 | 06:52 PM
Nick337's Avatar
For the amount of work, a hundred dollars is not bad, you can do it yourself.
Old Apr 30, 2009 | 08:06 PM
I hate cars's Avatar
Honestly, I would amp the stock speakers first and see if you want to go aftermarket. You would be surprised how much better they sound amped. Besides, they're usually used as fill, unless you're always carrying passengers back there.
Old Apr 30, 2009 | 08:13 PM
fade2blk's Avatar
Originally Posted by i hate cars
honestly, i would amp the stock speakers first and see if you want to go aftermarket. You would be surprised how much better they sound amped. Besides, they're usually used as fill, unless you're always carrying passengers back there.
^^^^ + 2
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
