HELP!!! power/amp question
Old Apr 1, 2008 | 11:57 PM
ecliptics's Avatar
steeez
recently i've been riding around with my buddys system in my trunk to see if its any different.. so we decided to swap back and BAM my shit dont work in my car no more... apparently i have no power comming to the amp i guess?
the ONLY thing that happend is that during the switch the ground and power wires touched.. they've touched before, but nothing happend. i accidently touched them again and during the touch my fuse blew out that time so i swapped it for a new one but still nothing works..
what i noticed though is that right when i connect the fuse, the power lights up for maybe 20-30 seconds then it turns off.. if i take the fuse off and connect it again same thing. so there HAS to be power comming to the amps but then it just stops?! can anyone help me... could the wires have all gone bad? am i gonna need to rewire the car if so thanks..
Old Apr 2, 2008 | 10:25 PM
ecliptics's Avatar
steeez
anyone?
Old Apr 2, 2008 | 10:38 PM
MWalsh9152's Avatar
all work and no play
you might have a loose power or ground connection? its enough to power it up, but as soon as it tries to draw more power it shuts off. Like if you have a loose wire on your starter or battery? check all your connections
Old Apr 2, 2008 | 11:18 PM
ecliptics's Avatar
steeez
sparking the two wires wouldnt result in the wire going complete bad though right..? the power cable connected to my battery looks fine (that was never messed with) and the ground looks fine.. bolted to my car..
i looked at my fuse box today and swaped it for a new one just cuz and still nothing
the only thing that could be wrong is the ground and power wires right?? but i cant find anything wrong with them
Old Apr 3, 2008 | 07:03 AM
MWalsh9152's Avatar
no I doubt that touching the wire would result in it going bad. Is it only one amp that youre having this problem with, or do you have multiple amps?
Old Apr 3, 2008 | 10:57 AM
rdenis10's Avatar
When the power comes on then powers back off that usually means you may of blew the amp.
Old Apr 3, 2008 | 02:48 PM
BukvaMan's Avatar
yup most likely the amp went bad
Old Apr 3, 2008 | 03:30 PM
ecliptics's Avatar
steeez
yea thats what i was scared of but then i was thinking to myself theres no way i blew the amp cuz the amp had no part in the sparks or anything.. so i tried the amp in my friends car and it works fine. so my amp is ok. any other suggestions? thanks for the previous responses
Old Apr 3, 2008 | 03:33 PM
ecliptics's Avatar
steeez
i tried putting my friends amp back in that was previously working and that amp doesnt work either.. yet both amps work in my friends car. thats how i narrowed it down to just the wires touching that i think caused all this, i didnt do anythin else different or that could have affected it.
i guess im going to have to get my hands on a voltmeter and see where the shortage is comming from.
Old Apr 3, 2008 | 05:01 PM
jvinhj240's Avatar
how about your fuse. 30 amp?, how about your power cable. it is 0,4, 8,10 gauge? is it 1000watts amp or 100watts? i have a feeling you dont have enough juice.
Old Apr 3, 2008 | 06:05 PM
ecliptics's Avatar
steeez
my fuse is 60wat and its fine, i even changed out the fuse box incase that was the problem.
cables are monster 4gauages
amp is 400wattamp, the other amp i had running before all this was a jl 500watt amp
i dont think enough juice is the problem.. friend is running the same setup and it all works in his car, and it all worked in mine too until i guess i sparked the two cables.
i understand this is a hard question for you guys cuz its osmething you'd have to look at to see, but thanks for trying. ill wait til i get a voltmeter and have my friend look at it. i just dont know why everything stopped working and i guess its cuz of the spark but ground/powerlines/fuses all look fine..
Old Apr 3, 2008 | 09:16 PM
1Clean_TL's Avatar
do you have a LOC, i touched the two while installing my system and i blew the LOC which my remote ran out of, switched out the LOC and everything worked perfect
Old Apr 3, 2008 | 10:56 PM
ecliptics's Avatar
steeez
LOC? is that the high low converter? yea i have a high low converter and was asking my friend if i should look at that but we both were thinking that the ground and power have nothing to do with that..
so you touched your ground and power and blew something connected to your remote? haha let me know cuz to check my high low converter i'd have to take apart some stuff on the passenger side... but if thats it thanks a million
EDIT:
hmm i just googled loc and i guess that is the high low, but how did touching those two wires blow the hi/lo?
Old Apr 3, 2008 | 10:58 PM
ecliptics's Avatar
steeez
Old Apr 4, 2008 | 12:11 AM
ecliptics's Avatar
steeez
hmm i just thought of something if your hi/lo was blown youd still get power though right? just the bass wouldnt work
Old Apr 15, 2008 | 08:48 PM
1Clean_TL's Avatar
i touched the power and ground that came out of the LOC, so it shorted out the circuit in the loc, which my remote ran out of, so dead loc = amp not turning on cuz the remote is no longer working, i dont know the logistics behind the wires touching i just know they did, i heard a pop and the LOC smelled smokey, changed it out and it worked fine
Old Apr 29, 2008 | 06:30 AM
ecliptics's Avatar
steeez
what do you mean ground that came out of the LOC. doesnt ground just go anywhere on the metal? mines at a random spot in the trunk
Old Apr 29, 2008 | 06:38 AM
MWalsh9152's Avatar
still havent figured it out? What he ment was the LOC has a ground wire coming out of it so you can ground the LOC if necessary. He touched the power and the ground from the loc together and shorted it out. In his case the remote turn on for the amp came from the LOC so his amp wouldnt turn on.
If your amp works in your friends car you need to start checking your power wires. Make sure you have power for the remote wire, I believe you said you already checked your 4awg wire so check the remote. Have your friend turn the system on while you watch the meter. See if the voltage drops out after it initially comes on.
Old Apr 29, 2008 | 10:05 AM
1Clean_TL's Avatar
yes, mwalsh, thank you for clarifying
Old Apr 29, 2008 | 10:36 AM
dope!'s Avatar
I'M BACK!!!
dooode its ur remote fuse..up under ur dash...chek that fuse. ive done tons of systems..n ran across this proble..chek ur remote fuse. recently this happened to me too..amp wud power on for like 10 seconds and turn off..it was the remote. either way chek all connections with a voltage meter. but im almos POSITIVE it has something to do with ur remote wire or fuse. and even though fuses dont look burnt out..sometimes they are but just dont like it.
Old May 2, 2008 | 06:36 PM
ecliptics's Avatar
steeez
doooode THANKS. that was the solution.. i was soo fustrated, i didnt know where the problem was, ground power remote all seemed fine. checked the fuses under dash like you said and it was fried.. got a new one at radio shack and bam
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
