HELP, navi not recognizing voice command
Old Mar 4, 2005 | 03:04 PM
dctobe2003's Avatar
Thumbs down HELP, navi not recognizing voice command
somehow navi is not responding correctly or simply not recognizing the commands. anyone got this problem before?do u need to record ur voice or train the navi to recognize ur voice? gonna take it back for a check up. still love the car thought
Old Mar 4, 2005 | 04:04 PM
R11S's Avatar
You do not have to train the navi. You need to give us more DATA. What are you doing (saying), what screen are you on when you say it ? Are you driving with your windows down?
Regards
Old Mar 5, 2005 | 12:32 PM
dctobe2003's Avatar
ok, im not exactly sure which screen i was on when this happened but its very inconsistant sometime. all the radio commands are working fine, but when it comes to climat control, info-restaurant, directions,etc. that is when the problems occur. i will test today again to see exactly under what situation this happens. And no, the window was never opened, zero noise inside car.
Old Apr 6, 2005 | 08:36 PM
naybag's Avatar
8th Gear
Ok. I am having this same problem. I can't setup the HFL. Car was parked all windows up (in 80 degree temp) with no AC turned on. And I must have said "Phone Setup" 50 times. It gave me the time, turned on the air, changed map views, did everything BUT give meoptions for the phone. I tried saying "system" as well and only got the time.
What could be wrong?
HELPPPPP!!!!!!!!!!!!
Old Apr 6, 2005 | 08:38 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
It sounds like you're hitting the nav voice button. You need to hit the button for the HFL on the front of the steering wheel (has a phone icon) to issue HFL commands.
Old Apr 6, 2005 | 08:41 PM
bluenoise's Avatar
Though I've had good luck with the nav voice commands, I just figured out a trick this week that helps a ton with the speed at which it understands me. Instead of flicking the button and saying the command, I flick the button, wait a moment, and then speak the command. It echos back my command almost immediately. If I don't do this, it sometimes misses the command or it takes a few seconds to figure it out. I suspect it's not really ready to "listen" the instant I hit the button, so it's losing the first snippet of my command and having a tougher time figuring out what it's supposed to do.
Old Apr 6, 2005 | 09:07 PM
naybag's Avatar
8th Gear
Thanks, I'll Try It
Ahhhh, I bet this is the problem!!!! I will try it in the morning. Duh!
Old Apr 6, 2005 | 10:45 PM
crazymjb's Avatar
Another story: My grandfathers friend had a car that you could tell to start. It wasnt working so he brought it in and they found out he was saying Staaht(with a Boston accent). Problem Solved. I dont know what type of car it was, I havent recently heard of a car with voice activated starting.
Old Apr 6, 2005 | 11:52 PM
TrashCan's Avatar
You are funny. So, what kinda the accent our TLs will recoginze?
Old Apr 6, 2005 | 11:56 PM
rets's Avatar
Moderator Alumnus
Practice, practice, practice... IMHO.
Sooner or later, you will pick up the right tone to say it all...
Old Apr 7, 2005 | 08:12 AM
naybag's Avatar
8th Gear
Yipppeee! I was able to get it to work! But of course, after finally getting the phone paired, I needed to clear it. I purcahsed the car preowned and their were several names inthe phone book. The previous owner had a thick accent. Apparantly, the system worked for him.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
ceb
ILX
Sep 27, 2015 10:56 AM
Cgannotti
Sep 25, 2015 05:04 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
