"Help! Nav keeps downloading"
Old 09-04-2012 | 11:18 PM
Desert Fox's Avatar
7th Gear
Unhappy "Help! Nav keeps downloading"
Greetings to all,
Just happened today. Noticed when I start the car, the nav display's "downloading software, do not shut engine off". Then it asks for my code which I input and then the cycle starts all over again, down loading software do not shut engine off, ect. I've tried everything from disconnecting the battery to installing an old nav disc. to no avai. My son suspects the DVD reader in the trunk may have gone south. After reading some of the threads here on the forum, this may be the case but I'm not sure. I know the dealer is gonna soak me if I bring it in so I thought I'd you guy's for some input. This is a 2004 TL stock system. Any input would be highly appreciated.
Thanks,
Desert Fox
Old 09-05-2012 | 12:34 AM
VanyDotK's Avatar
If I remember correctly you should be able to call Alpine and send it in to them for repair for 358 dollars. If it's just not reading discs I can't imagine it would be too hard to change out the laser.
Old 09-05-2012 | 10:23 AM
Desert Fox's Avatar
7th Gear
Red face
That's what I'm going to do. I'll call them this morning. I live in the L.A. area and I think their service center use to be here in Torrance but has moved to Garden Grove, which is not far from here. Mabey I can just walk it in the door. Thanks for the response.
Old 09-19-2012 | 09:55 AM
chaddfaulk's Avatar
I had Alpine fix mine as well (I live in FL tho)...customer service was awesome, and it works perfect now...mine was doing the same thing.
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
Quick Reply: "Help! Nav keeps downloading"
