help my system has a hum in it
wdp skyhawk
i got a some subs installed in my 2008 acura tl type s i have a 1farad cap and a 2 channel amp and when you cut the car on the speakers get feedback that goes away when you open the driver door or cut the car off. is the ground bad?
PXAMG GuRu
periph.... the stock amp remote cable reads 9 volts......depending on the amp hes using it may not work with it. I never checked it behind the radio but im pretty sure it reads the same voltage.
Retired!!! ON TOP!!!
He did say it's a 2008 TL Type S... so it must be what godizus said, the noise cancellation system... so he must disconnect the mic from that ACS...
Good Luck
PXAMG GuRu
we offer an LVT2 or Low Voltage Trigger. It takes a trigger that is not quite 12V and boosts it up to 12V. Its implemented into our SVENR or is sold separately.
wdp skyhawk
Originally Posted by Peripheral
This will all go away if you run the amp off of a remote wire. your system is currently wires to an IGN circuit. so the amp is turning on before the radio does. this will happen with the door closed and the radio off or on with the volume low. if you ise our SVENR it has a trigger that sinces voltage on the speaker wire and then turns the amp on. that is incase your factory radio doesnt have a remote output or amp turn on.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
