Help with Amps...
Old Nov 20, 2011 | 10:10 AM
Ramos22j's Avatar
Arrow Help with Amps...
hello i have a 2006 Acura tl with the following replacement speakers in ....
Rear Deck: Polk Audio db651 2-Way 6.5" Car Speaker
Front Doors: PIONEER TS-A1684R 6.5" 4-WAY A-SERIES SPEAKERS
Center Speaker: POLK AUDIO DB351 3.5" 105 Watt 2-Way
iknow the speakers arent at their best right now and im guessing is because of its runnin on a stock amp.
I need to know if i need more than one amp so all can produce at their best.
Old Nov 20, 2011 | 11:30 AM
geekybiker's Avatar
They make amps with enough channels to run everything. However most people end up with two if they want everything running. You're looking at 6 channels minimum, one of those being the sub which requires quite a bit more power.
Old Nov 20, 2011 | 11:46 AM
Ramos22j's Avatar
ok cool thanks
so like how many watts should the amp be?
Old Nov 20, 2011 | 12:35 PM
Trunk Monkey's Avatar
Coolest A-zine Member
Can I ask what you're looking for in a system??
Are you looking to get loud? Are you looking for the best sound quality you can? If it were me I'd sell the fronts and buy a pair of quality components. I'm not sure if you like the whole sound all around you feeling that you get with rears or if that's what you're going after but a solid set of components up front will fill the car more than enough. Your soundstage will be up front like it should and you won't have to power multiple channels like your setup now. I mean it's up to you...just trying to give you another option that you might not have thought about.
Get new fronts and use the stock amp to power the rears and center. That will be plenty for those. I, along with quite a few others, don't use rears. If you would want them for fill..the stock amp will be enough to give you that fill. That way you'd need 2 channels for the components up front and that's it. If you wanted to add a sub later, buy a 4 channel and bridge the other 2 channels when you get a sub. I feel like you might just be polishing a turd when amping 5 channels of mediocre speakers ya know.
Old Nov 20, 2011 | 01:02 PM
Ramos22j's Avatar
i want lound and quality.. right now it isnt so bad but its like i crank it up to 40 and i ask myself thats all?
i do want to add a sub in the back but not right now because money is tight but i want that loud and with quality sound.
So how about this
1. remove the pioneers
2. add Polk Audio DB6501 DB Series 6.5" Component Set
3. And a 4 channel amp because i will add the sub in the back
IF not wat components do you recommend..and what amp as well?
Thanks alott
Old Nov 20, 2011 | 03:20 PM
Yeah..my ears will bleed at 40. A better set of speakers and more power will wake it up. Plus you're going to run into distortion above 30ish..and the factory amp is already pretty noisy.
What's your budget for speakers and amp?? Not counting if you sold the fronts for a little more to help ya
Old Nov 20, 2011 | 03:36 PM
Ramos22j's Avatar
Probably like 300 buks total...
what do you have in mind?
JayVee
1167
Feb 12, 2014 07:17 AM
PKIM
Socal
Jul 15, 2010 12:10 AM
cp308
Jul 14, 2009 07:47 AM
ron_c1
14
Aug 11, 2008 05:43 AM
wong05tsx
Jun 16, 2008 02:51 AM
