Help!
Old 07-20-2015 | 03:39 PM
Oh Sickest TL's Avatar
Jeff
Help!
So my car is a 06 TL non navi and I went to my local car audio installation shop "custom auto" today to see about getting a aftermarket unit put in like a pioneer screen or something along those lines, and they said they can't do it as no dash kit is available for the 06 TL?? I find that kind of weird considering I browsed through here and see MULTIPLE guys with functional screens.. I know nothing about electronics so what can I do? A DIY would totally out of my league for this.
Also my buddy is going to sell me a custom box with 2 10" subs and a amp for a steal of a price.. Will that wire right up to my stock system?
Old 07-20-2015 | 03:47 PM
Hey Jeff!
up until recently, maybe 2012 or 2013, we DID NOT have "dash kits", so there was no way to install a double din, unless you fabricated the hardware yourself.
now, in 2015 we absolutely do have a "dash kit"!!
let me see if I can dig up some of the threads where they are selling them. hang on.
So, maybe the shop you went to was relying on past information.
Oh Sickest TL (07-20-2015)
Old 07-20-2015 | 03:49 PM
Flipster23's Avatar
Stock system you will have to run a LOC. Well that's what I ran.
I ran a Audiocontrol lc6i
Old 07-20-2015 | 03:50 PM
Jeff
thanks justn and what do you mean run a LOC?
LOL at your avi flipster
Old 07-20-2015 | 03:54 PM
here is the Double din kit Straight from the manufacture.
2004 2005 2006 2007 2008 ACURA TL DOUBLE DIN DASH KIT
LOC = Line Out Converter
Old 07-20-2015 | 03:57 PM
chief wiggum's Avatar
Autoware302, a seller on EBay, has a double DIN dash kit available for under $45 including shipping.
justnspace (07-20-2015)
Old 07-20-2015 | 03:59 PM
Jeff
BINGO
^good shit, chief wiggum!
Old 07-20-2015 | 04:01 PM
Jeff
so what will I need to do to rig up my 2 10"inch subs and amp?
Old 07-20-2015 | 04:06 PM
- amp wiring kit
-LOC
wire LOC to stock sub. positive wire to positive wire from sub, negative to negative.
LOC will have RCA ends so that you can hook up to amp via RCA
Old 07-20-2015 | 04:09 PM
Jeff
^^expensive??
Old 07-20-2015 | 04:13 PM
^^expensive??
do the ebay double din kit for $45 plus shipping to canada!
and then do like a $10-15 LOC. which can be found in audio shops in CA.
Old 07-20-2015 | 04:15 PM
Jeff
yezzur
Old 07-20-2015 | 04:50 PM
If you purchase an amplifier installation kit, it will usually include a 17-foot RCA cable, 4 or 8 gauge power and ground cable, fuse and fuse holder, and split loom. Amplifier installation kits are available online from Sonic Electronix, EBay or Amazon, or can be purchased from your local stereo shop. Be aware that although the packaging might say it's 4-gauge wire, it's highly likely not, especially if it's priced cheap.
If you decided to replace your factory radio, you want to budget in the cost of the installation supplies you're going to need. Do you want to retain the steering wheel controls? If so, then you need either an Axxess Interface ASWC-1 or a Pac Audio SWI-RC.
For ease of installation, you might want to use a Metra 70-1721 harness, however, if you're planning on retaining the factory amplifier, you're going to need to solder male RCA connectors to the speaker leads on the harness. The factory amplifier uses a low level input.
There are several things to consider prior to performing your installation. It's best to map things out and ask questions, before jumping into this blindly.
Old 07-20-2015 | 05:01 PM
^dont know who you are but i love you
Old 07-20-2015 | 05:12 PM
Flipster23's Avatar
I like Knuconceptz, but there are other brands out there as well.
You already got your answer for the LOC.
Old 07-20-2015 | 06:52 PM
Most amplifiers available have high (speaker) level inputs, so purchasing a LOC might not be necessary. Once again, it comes back to whether or not he's going to install an after-market stereo or retain the factory.
Old 07-21-2015 | 12:12 AM
Jeff
would most likely retain the factory now that Ive been looking, It just seems like a lot of money to dish out to get rid of factory radio setup
Old 07-21-2015 | 10:43 AM
Here is the subwoofer output from the factory radio:
Yellow/Black (+)
Light Green/Red (-)
Here is the amplifier turn-on from the factory radio:
Red/Yellow
Locate these wires at the harness coming out of the back of the factory radio. Cut the subwoofer output wires in half and attach a female RCA to the radio side of the wires. The factory subwoofer will be inoperable, which is fine since you're planning on using an aftermarket amplifier and subwoofer.
Splice a wire to the Red/Yellow wire at the factory radio harness and run that to where you're planning on mounting the amplifier. That will connect to the remote turn-on wire of your aftermarket amplifier.
With that said, you should be able to do this relatively inexpensively.
Oh Sickest TL (07-21-2015)
