Hardwire kit for Passport 8500..
Does one exist? It would be nice to jump the power off of the mirror or the map light as opposed to having the cord running from the cig lighter. I know Passport makes one, but i was curious if there was a TL specific one that someone is distributing..
TIA..
TIA..
Originally Posted by rbf351
make your own
all you need is a phone cord, and hook the green and red wires up.
Red being remote on off, and green being ground?
Where have you guys jumped power from etc?
if you search "escort x50 install" there are a few threads on this. you can go to best buy and pick up a smartcord for $30 which includes an inline remote button that can be mounted in the blank near the vsa switch or really anywhere you choose. I am going to attempt to mount my mute button in the bottom storage tray.
BTW thanks, i'll do a search for x50.
Registered User
i did my install over 2 years ago on this car, red is power, green is ground. all i did was tap directly into the over console, and in there you'll find ground and switched power. no need for a fuse, but if it makes you feel better you can wire one in
Registered User
Originally Posted by ..Mark..
Picked up a phone cord and plan on doing this mod tomorrow. The only problem is the phone cord has red, black, green, and yellow wires. Which ones am i running where? I thought i would just be dealing w/ a power and ground. WTF??
just use the red for power, and black for ground.
in a telephone wire the green and red are used for line 1, and black and yellow are used for line 2
Registered User
Originally Posted by Evader
I powered my 8500 to the fuse box. Unit turns on and off with the ignition!
why run that much wire when one of the wires in the overhead do the same thing?
Registered User
I agree.. Took me maybe 10 minutes to get the housing up top off, run the wire, and hook up the ground. Now i'm just waiting for the wife to come home and watch the kid so i can run to home depot. I didn't realize i was out of wire taps.
I don't get it, i grounded the black and jumped the power off of the green wire w/ the white stripe (far right), onto the red wire from the phone line and nothing..WTF??
Am i on the right line for the switched power? I'm using the sunroof wire harness (green) and not the one for the lights (black) , right??
Registered User
you need to use the yellow/red wire (pin 1) on the green 22 pin harness which is for the HLF unit, and if you want a ground wire use black wire (pin 13) on the same harness
Registered User
I didn't see a yellow/red wire.
Check out this pic i pulled from another post. Which wire are you refering to?
thats a 14 pin connector, which is for the map lights and homelink, if you take out the 8mm or 10mm bolts you'll see another harness near the windshield which is for the HFL unit.
Registered User
i'm wrong thats a 7 pin connector, and thats the sunroof switch harness. the map light/homelink should be 20 pins and black/white in color. but either way the HFL harness is under the plastic, which comes out with the 4 bolts
So when i get to that harness after taking our the 4 bolts am i jumping the red and yellow or the green?
Registered User
Registered User
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
