Groundbreaking Info! Hack your Navi! (Change Pics, Remove Nag Screen) (Garage I-139)
#201
Ok. Success! Here are some of my images. Went on a little HHG theme here:
Files are stretched to correct for aspect ratio. Easy to do with Photoshop:
Image > Pixel Aspect Ratio > D1/DV NTSC (0.9)
Then just put it back to square when you're done making it.
If anyone wants the source photoshop files, you can get them here. 1.5mb file.
http://www.thedude42.com/acura/hhgscreens.rar
#206
Team Nighthawk MechE
Originally Posted by TheDude42
I did that, but there was no working link on any of the pages. All I found was nsx26.ttf, which looks kinda crappy....i.e. the bottom of some of the letters is too thick.
Any chance you can post the font?
#207
Made this one
Looks pretty good. For anyone who cares, it's from an Israeli F-15 I got to mess around in and take pics of.
You might notice a resemblence with my avatar
#209
Originally Posted by Acuraluvr
will grayscale/black and white photos work too?
#212
Originally Posted by copter
No, I am too.. I get the "Unable to open bootloader file" warning. All 9 .bin files are there. What am I missing?
#215
Originally Posted by TL-CrAzIe-05
How do you remove the read only file???
#216
Chief
I have right clicked on several of these bitmap pics and saved them in my pictures area on my computer...the size is at 480X234 but the bitmap size when I right click on properties says 24 bitmap. How do I change this to 8 bitmap so that I can use some of these different pics. The only one I have been able to use is the ACURAZINE one.
Thanks for the info.
#217
Iro Ridg .308
use adobe photoshop or macromedia fireworks to do it. if you wanna save some cash, you can actually download a 30 day trial for macromedia firworks then do the bitmap changes.
#219
Team Nighthawk Director
Made this one
#220
Originally Posted by dysd
I have an 04 TL and i get the no-nag is not supported for your vehicle. ANy ideas? The background change works just fine.
#221
TL hacker
Holy shit! Ok, now this has ignited the programmer in me with some new inspiraton.
Since it's Win-CE and it's a SH-4 processor, I've got the tools needed to do some fancy stuff.
I used to write some simple apps for my Pocket PC in VC++ and VB (Mips processor). So assuming I can disassemble the navi program properly, I might be ale to add new features to it. BTW, the Win-CE tools for VC++ and VB have different target platforms (Pocket PC, embedded an auto-PC). Auto-PC is what I'm assuming navi.exe was compiled for.
So here's my project: Phone dialer!!!
Insipration: When using points of interest, some of them have a phone number. You can then press the "Send" button to dial the number. The assumption is that there's a dial() method somewhere in navi.exe. If this is the case we could exploit this.
Design: The phone dialer would be accessed through the "Info" button. Currently the info button has a Calendar and Calculator app. Option #3 would be "Phone dialer".
Dialer would simply show a phone keypad with a "Call" and "End" button. A text entry box would be at the top to show the number you are dialing. I would probably have to include a "delete" and "clear" button on the screen as well. You use the touch screen to dial the number and then press "Call" to start the call. Pressing "end" or the steering wheel button would hang up.
If successful I would develop later versions which would include a phonebook with names and numbers. They could be sorted by category too, just like the personal addresses.
Why? several reasons:
1 - The voice dial often doesn't pick up the right name or starts doing other things I don't want.
2 - When you have a passenger that doesn't shut up, he messes up the dialing sequence. Usually first time passengers who say things like: "No way, you can do that?" while the computer is still listening.
3 - Sometimes I don't remember under what name I stored some phone numbers so I have a hard time recalling them.
4 - I could type in the phone number on the screen and still listen to the radio. Only when I'm ready to call I would then press the "call" button. This is useful when you hear a phone number from the radio and want to call in to a radio show.
5 - Because it's fun! I just want t osee to what extent we can modify this navi.exe program.
Timeframe: I have no idea! I don't even know if I can pull it off at all!!!! But I seem to have all the right tools to do so. Obviously if I had the full navi.exe source code, the real one, I could probably pull it off in a week or so. But since I don't I'm going to have to try to reverse engineer this navi.exe to figu out exactly how it works. That's probably going to be the hardest part. Adding a new app to the info list will probably be easier, assuming it's properly written object code to start with, which I assume it is.
#222
If you accomplish this I will idol you!!!!!!!!!! Please please set time to figure this out. If I was as good with C++ and Visual Basics as you are I would soooo do it. But I'm not =(. G'Luck and keep us posted!!!!!!!!!!
#223
TL hacker
Originally Posted by underdog_RENAMED2
Yeah... what it is about the no-nag for the TL that is different? Is it just that byson cannot test it, because he doesn't have a TL?
#224
Moderator Alumnus
#225
Community Architect
robb m.
robb m.
good luck Zeuser. Show us your stuff!!
#228
Team SSM
oh wow noone thought of telling bysin about a phone dialer, good thinking
and while you are working on that, think of a way we can get some music visualizations. hehe
#230
Hey, I still have a copy of the Dreamcast MP3 player (DCMP3.EXE). Since the processor is the same, what do you think are the odds of getting this to run on the TL Nav system?
#231
Any updates, That trip computer looks hot. I want to add some features so bad. As said before we are all relaying on you. Is there anything that I could contribute?
#233
04 TL 6MT NAVI ABP/Q
This thread mentions the ability to remove the Nag screen but just to be totally clear, no one on here has gotten this to work on a TL yet right?
#234
#235
Yes.. I have been able to get it to work. If you follow the directions Bysin gives you, its the exact same procedure for the TL... it works beautiful in my 2005 TL. You cannot remove the nag screen yet, although you can blank it out... and you can replace the initial Acura picture with wat u want.
#236
#237
#238
Chief
Spackletoe:
That's it exactly!!! The nag screen writing goes away and is blank and then the go button comes up. You still have to push the go button in order to get the Navi functions to work.
#239
Scoobie Specialist
So basically this will change out the initial acura screen for whichever one you choose, and then the nag screen changes to a simple black?
Is there a way to change the nag screen to a picture?
Thanks,
Mike
Thanks,
Mike
#240
GAME ON... NHL RULES!!!!!
Okay, Really Dumb Question, so bare with me...
Can these hacks work on any of the other gen's of the cars? I've got an '03 TL-S, and I'm itching to mess with it. Or is this strictly for the newer Honda/Acura navi systems?
Thanks,
Frank~Frank
Thanks,
Frank~Frank
