getting to the front tweeters
my front left speaker came loose (the tweeter on the dash) and noe its rattling
how do i get to it?
the serive manual i have for soem reason doesnt have the pages i need (those and only those pages )
can i pry the grille up?
i removed the air vent but still cant get to it
i hope i dont haev to remove the whole dash
how do i get to it?
i found a better way
probably too much detail for such a simple task but I wish all tutorials were like this
i used 1 paper clip
straighten out the clip, and at the end make a 100 deg (so it has a little of a V shape) bend
do this with plyers as this bend should be like a couple of milimeters
now on the tweeter look for a spot on the grill that is JUST beside the tweeter hole ( like where the plastic under it STARTS)
you want to do this because just pulling the grill with the paperclip hook will probably damage and bend it - so we want to pull the plastic UNDER the grill, so again, find a place where the plastic just ends (an open hole) -- so now get the tip of you paperclip in there -- point the hook part away from the plastic edge at first and then once its in you can twist the paperclip so that the hook is now under the plastic part now just pull up
- the clip might bend so youll have to take it out and reform it
- dont use cheap paper clips, itll break and bits of paperclips will be bouncing around in there
- if you can bend the top part into a sort of handle that will make it a lot easier to pull
- as soon as theres anything for you to pull on, use your hand
- take note of the posistion of the module it goes in a specific way, as youll see from the clips after u get it out
i used 1 paper clip
sockr1
10-01-2015 01:31 AM
