Garmin or Nuvi GPS Integration with HFL
I have 05 TL no Navi.I want to buy a GPS device. I want to know, if I can get the diretions and street names from GPS heard through my Acura HFL.
I foud Nuvi 680 where the directions will come through FM channel. Did any one used this before?
Thanks in advance
Thanks in advance
The HFL is designed for cell phones. Aftermarket GPS will not be able to connect to this (even if they have Bluetooth).
FM is another story. If your portable GPS unit has a FM transmitter (built-in or attached), then yes, you can configure the settings such that the audio of the GPS will transmit to the TL's stereo system (via FM transmitter). The disadvantage is that you'll be locked into the audio of the GPS unit and won't be able to listen to music while listening to the GPS. You can only listen to one or the other; not both at the same time.
phillyguerrilla
09-26-2015 11:27 AM
4drviper
09-23-2015 09:00 PM
