Fuse box problems
Old Jun 24, 2015 | 09:03 AM
kylewheels's Avatar
5th Gear
Fuse box problems
Hey guys,
I just got an 05 TL that has a moonroof that isn't working. I've taken it apart and found that the moonroof motor isn't getting any power to it, so I traced the wire back to the fuse box & found where the wire goes into the fuse box (at connector X). The wire has continuity from the motor up to connector X. The fuse (No. 28) is good & shows 12V coming across it, but the wire coming out of connector X isn't getting any voltage.
Please help! Is there a way to fix this without having to buy a new fuse box?
Old Jun 24, 2015 | 10:12 PM
klanza's Avatar
Is this the interior fuse box? If so I have an extra one that I ended up not needing. I would let it go for cheap also. Have you also checked relays?
Old Jun 25, 2015 | 08:49 AM
polobunny's Avatar
Registered Bunny
Hey kyle, I saw you sent me a PM. Have you ran the tests like in the service manual?
https://acurazine.com/forums/problem.../#post15457691
Most of the steps can be done with a multimeter and should be done prior to changing parts left and right. You don't really need to trace the wires or anything.
First test is green wire (8) to ground and check if there's voltage. Is there voltage? If not the service manual is pretty clear on that, either fuse 28 is blown (make sure it is working by swapping it for another one), there's an open in the wire or it's fusebox/relay box issue.
Work from there doing all the steps 1 by 1 to figure out the issue.
Old Jun 25, 2015 | 09:45 AM
kylewheels's Avatar
5th Gear
yeah, it is the interior fuse box. I got it worked out! the green wire wasn't getting voltage. I traced it back to where the green wire comes out of the fuse box & found out it wasn't getting any power out there. I just clipped the wire and wired it through a 20 amp fuse to a 12 V power source.
Old Jun 25, 2015 | 03:57 PM
guitarplayer16's Avatar
wow, awesome fix
Acura9915
Feb 24, 2020 01:27 PM
spidermankb
Mar 5, 2019 11:34 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Fandango12
1/2G MDX (2001-2013)
Sep 20, 2015 05:25 PM
Soul_Deamon
Sep 7, 2015 04:25 PM
