Front Speaker Q's
Old Mar 17, 2014 | 07:34 PM
jbeck's Avatar
Front Speaker Q's
I have seen two different measurements on here for the front speakers, I wanted to get some conformation.
I have seen 6.25" & 6.5". I believe I saw 6.25 in the stickies but pretty much everything else states 6.5". Has anybody ever had any issues trying to put a 6.5" driver in the front?
For anybody with deeper than stock speakers, what did you do to accommodate for the extra depth? Mdf rings?
Also, has anybody not ran rear speakers in this car? Just front components? If so, how'd it sound?
For reference, I'm going to put my Hybrid Audio Clarus set in the doors with a 2 7/8" mounting depth vs 2 1/8 inch stock depth.
Where is the best place to put the crossovers?
Old Mar 17, 2014 | 10:57 PM
I hate cars's Avatar
These questions have been answered a hundred times and are likely in the FAQs.
I have 9" Dynaudio speakers flush mounted (no MDF rings) and no mods other than cutting the hole larger so the worst possible outcome of installing those speakers is having to cut the hole larger which you will have to do with pretty much any aftermarket speaker. The hole is a "D", even with the use of an MDF ring which is recommended you'll probably have to cut it for clearance.
Crossovers can go pretty much anywhere except for the doors.....keep them away from moisture.
Old Mar 19, 2014 | 11:27 PM
jbeck's Avatar
Like I said I saw many different answers for a few of the questions I had asked so I wanted some confirmation. I appreciate the insight though. I'd just tear the door panels off myself to check, but it's still ~25 degrees here in WI so..a little too cold to be outside experimenting on my car.
Like I said, I appreciate it.
Any idea on why the stock speaker mount is in a D shape?
Old Mar 20, 2014 | 07:47 AM
DiamondJoeQuimby's Avatar
Codename Duchess
The speaker itself is right at 6". But it really doesn't matter. You will have to at a minimum cut up the plastic housing for anything aftermarket, even a 6". You may still have to trim the door metal too depending on depth. Get what you want and just plan on cutting.
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
Pegon95
Sep 15, 2015 01:54 PM
08 NBP TL
Sep 8, 2015 08:49 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
