First time amp and sub install questions
Old 05-30-2012, 11:06 PM
winkyyy's Avatar
So I have a a JL 10w3v3 just sitting in my garage and I was able to borrow an amp from a friend of mines. I just want to verify whether I'm installing it right.
First I would take the stock sub wires and plug it into the LOC, and from the LOC, I plug the RCA cables into the amp, and then plug the JL sub into the amp. Then ground and power the amp. correct?
Also do I need to tap a remote wire anywhere? or should I just be fine without one?
Old 05-31-2012, 12:24 AM
pohljm's Avatar
sounds like your on the right path. depends on the amp if you need a signal wire or not.
I think you will need to disconnect the ANC microphone too or you will get awful feedback
winkyyy (05-31-2012)
Old 05-31-2012, 01:55 PM
winkyyy's Avatar
ANC microphone? What's that? Sorry I'm noob to all this car audio stuff
I read through the owners manual and it says its not recommended to use loads under 4 ohms for a mono setup. But I can use 2 ohms for a stereo setup. And my sub is 2 ohms. Should I just refrain from the whole installation till I get a more compatible amp or would it still be okay to use the amp without damaging anything?
Old 05-31-2012, 02:39 PM
Coolest A-zine Member
Trunk Monkey's Avatar
Just search for something like "anc removal" in the search function here. It'll pop up as it's common and you have to do it on the 07/08's. Simple task though..
What is the amp you're using? Everything you said is correct, but you will need a remote wire. Just add a "add a fuse" into Fuse #32 in the drivers side kick panel fuse box.
winkyyy (06-01-2012)
Old 05-31-2012, 02:47 PM
winkyyy's Avatar
What is the amp you're using? Everything you said is correct, but you will need a remote wire. Just add a "add a fuse" into Fuse #32 in the drivers side kick panel fuse box. The owners manual means you don't want to use the stock amp at any ohm load under 4, but you won't be using the stock amp.
Im using a Lightning Audio S2.400.2.
Old 05-31-2012, 02:48 PM
Is your sub a SVC 2ohm or SVC 4ohm?
Old 05-31-2012, 04:38 PM
Dogmatic Dinosaur
jda123's Avatar
You will eventually melt the FETs if you bridge that amp at 2 ohms. You will have to read the manual and see if you can use just one channel in stereo - some can, some can't.
Even if you have to get a new amp, there should be plenty of cheap, available options for you.
Old 05-31-2012, 06:04 PM
if the w3 is 4ohm then you're fine
Old 05-31-2012, 06:48 PM
winkyyy's Avatar
Damn it my sub is a 2 ohm.
Old 05-31-2012, 06:51 PM
You can run that amp, but you'll only be getting like 100-150 or so @ 2ohms
Old 05-31-2012, 11:51 PM
winkyyy's Avatar
Would it cause any harm to the sub or the amp if I do that?
Old 06-01-2012, 09:13 AM
Dogmatic Dinosaur
jda123's Avatar
Make sure that amp is good running only one channel before you do it. Some are, but some are not. The issue is that the main power supply can easily handle the load for just one channel (since it was designed to handle 2) and if the single side is not regulated to not just "take" all of that power, then they can get overrun and melt. This was not a high quality amp, so who knows how much protection was built into it.
If you don't want to risk it, just get a cheap D class monoblock since most all of these go to 2 ohms and you only need 300-400 watts.
Old 06-01-2012, 03:54 PM
winkyyy's Avatar
Yeah I really don't want to risk it damaging anything especially since this is a cheap quality amp. I'm probably just gonna save up and pick up a JL 500/1.
Are there any downsides to picking up a used one instead of a new one? I understand that you should smell the used amp and if it smells burnt, it has probably been used incorrectly and damaged.
mada51589
05-03-2022 08:54 PM
IIDXholic
10-08-2015 07:53 AM
lland
10-04-2015 04:47 PM
Skirmich
09-15-2015 06:41 PM
Quick Reply: First time amp and sub install questions
