First Post, Soon to be New Owner, Upgrading Car Audio Immediately
#41
That's not a bad idea. Right now if I crank it up, I even get a loud rattle on the outside of the car from the midbass, I think it's either the door hitting the glass or the mirror or some linkage or something inside the door. I'm probably not going to do anything right away, there's a very good chance everything will be up for sale soon.
#42
#44
Maybe, but theoretically by having braces in there, especially if you can get them close to the woofer the vibrations will be reduced. Like a card box, you can crush in the sides easily when it only connected by the ends but after you put a few crossbeams in it it it's much, much stronger. The pressure / force is distributed over the whole object.
#45
Still no luck stopping mine from lighting up. I have speakers in the doors that will play from 35hz and up with authority but I'm low passing them at 80hz and still cutting 63-120hz a lot.
I had good staging with low volume that wandered as I turned the volume up. With the midbasses castrated I have a good stage all the time. Luckily my subs will play as high as I want them so they're now playing to 100hz but have some serious cuts from 70-200hz due to their efficiency in that range. The stage is actually better even with the subs playing pretty high.
The moral of the story is even if you think you can't hear the rattles at high volume, its likely still degrading the sound. Deadener and getting rid of rattles is one of the most important things you can do, at least as important as the equipment. I found my rattles by muting everything and playing only one set of speakers at a time.
One other issue with stage was the upper console and rearview were making everything fuzzy at high volumes and low, low bass. I still haven't fixed it completely but it's quiet at any sane listening level.
To OP: Here is my build thread going on right now if you want any additional ideas in addition to the many other great build threads on here. Several of us have gone the infinite baffle route (mine in progress as we speak!) for subs that you may want to consider. Also awesome that you got free SDS material! I contacted Don at SDS and love his site but ultimately am just using what my installer has. If I were putting in an acoustic barrier (MLV) in addition to the dampending CLDs I'd definitely go with SDS!
Also - from what I've heard the 3sixty.3 is quite good, I got my PS8 for $725 and it's considered the best on the market currently, so that's another option for a couple hundred more. Allows for extremely fine tuning, down to .1 db increments on each equalizer band.
#46
And the moment everyones been waitig for!......
Its an 08 Acura TL Non-Navi.
What're my options, GO!
I've put in a return request for the Pioneer DEH80-prs. Should I continue down that road? It seems the JBL MS8 and the 3sixty seem to be within my price range. Don't really feel like decking out 725 for a processor. The MS8 I've heard is easier to use overall vs the 3sixty. I like easy, especially since I'm not super knowledgeable, just been doing research and talking on forums the last few months.
#47
Both Matt (i hate cars) and Jerry (niebur3) had MS8s and didn't like them, from what I read. I haven't heard either but I'd trust that opinion. So between those two I'd choose the 3sixty for sure. You may also want to get a used Audison Bit One for around the same price. It's a higher performing unit than either of those.
#48
bout time sheesh!<<- sarcasm
I have an 06 but on the 07-08 I think there's a mic in the back that needs to be disabled or it can wreak havoc on your aftermarket system. Do a search or maybe somebody else will chime in with more specifics.
As far as processors go I have the 3sixty.3 and really like it. I paid a little over $400 for mine new and it has a lot of processing capability for the money. Sure there's others that are "better" and can be considerably more expensive but once you reach a certain level of functionality its really starting to split hairs imo. Like going a 160 mph vs 150 mph. They're both very fast... Trust me I've done a 150 mph before and it's fast. lol. but that's another topic. Things like proper speaker installation are more important. You can have a $1000 processor but if you leave a gap around a door speaker allowing the back wave to interfere with the front it's still gonna sound like crap. Almost all of the dsp's out there have certain quirks, and the 3sixty.3 is no different but once you know what they are you're good to go. With any dsp the first thing you'll want to do is update the firmware. After you get your system tuned good turn the DSP off and on during the song and you'll hear what a night/day difference there is. A dsp is the next best thing you do to any system after adding subs.
Also, I would set aside about $150 for a good mic like the dayton emm-6 and a preamp like the Art dual USB pre . Then get a copy of TrueRTA and find a couple target curves to play with and have fun. I run 16ft usb and xlr cables from the car in the garage to the kitchen table and tune my system while I'm having a cup of coffee.
Here's a link to some popular target curves.
http://www.diymobileaudio.com/forum/...omparison.html
#49
I don't think I'll be getting too high tech into this stuff guys...as much as I enjoy the hobby and learn more every day. I just want to have a basic system, tune it with some help from some forums/youtube/google. Then if I want to get down diggity into the whole thing I'll start trying to aim for a "flat curve".
The objective is...as long as I'm happy.
#50
Several of us also started out with the best of intentions of having a simple fairly low-cost system, then got sucked in... I'm really just getting started - done lots of research but don't even have my install complete yet! I read a lot of the threads with Matt (i hate cars) and he started back in like '09 as a newb and kept upgrading his system until he has one of the best on the forum.
I think most people end up being happy with a simple install, though.
#51
I'm not afraid to use my money, just rather see what I can do with $1200 (Which is a good budget IMO) and if I ever want to upgrade I know where to come learn and get good opinions.
If I were to go with the 3sixty.3, how does the installation go about? Same as a HU? Get a wiring harness, hook it up, plug in RCA cables from amps?
#52
#53
Rockford Fosgate RFI2SW Adapts High Level Speaker to Low Level RCA Adapter
#55
So if I went and purchased a 3sixty.3 today, is there ANYTHING I will need besides that? I thoroughly appreciate the help I've been given by you guys. Alot of nice looking builds. Exactly why I got a TL, alot of room to toy around with.
#56
Yeah the TL is a great car to work with imo. Easy and straight forward. It's also perfect for infinite baffle. I don't know if you ever heard subs in IB before but if you upgrade anything else I would suggest going with IB first. I think once you hear how good it can sound you'll never want to go back to a sub in box... and it hardly takes up any space in the trunk. Perfect for one or two 15's. I have 15's because they don't need to move very much to get a lot of output so distortion is practically non-existent with them.. and let tell you it sounds so clean.
#57
I just started digging around on IB subs only because my cousin has a pair of Kenwood KFC-W3013PS, sealed, that I was told that they spec out to be IB subs. I'd love to take up less room =). The first thing I was going to do was mess around with boxes once every few months or so, or if I just disliked it overall.
#58
#60
If you don't plan on getting measurement equipment you should buy a processor with an auto-tune feature like the MS-8 or one of the Alpine units. I know people like to talk about tuning by ear, but in reality without taking measurements, you are really just guessing - and are probably guessing wrong.
If you do plan on taking measurements there are lots of good DSP's with manual tuning that will work great. One that hasn't been mentioned is the Zapco DSP-Z8. I think it retails for around $500 and can likely be found for less than that. I saw a brand new one for $385 recently. Also, The Rockford 360.3 looks to have everything you would ever need from a feature standpoint.
Gregg, so did you pick up the EMM-6 and ART Dual Pre? If so, how do you like it?
#61
I have yet to decide on the pre-amp stage. I'm leaning towards the Blue Icicle. I was tempted to get the Dayton UMM-6 which has the USB pre-amp built-in but apparently it has a little higher noise floor.
#62
#63
So Greg, at your recommendation I ordered a calibrated Behringer mic. Every time I think I'm done sinking money into the system, something else comes up! LOL.
I believe by the time you're done researching it you'll have picked a good pre-amp.
#64
Yep, got them along with TrueRTA level 4 shortly after talking to you. It's pretty nice. After figuring out the best crossover slopes and t/a tuning is easy. Now I know I'm doing it right and not wasting time pretending like I an expert tuner with a golden ear. Lol. I can tune to target curve from the comfort of my kitchen table in 30 minutes or so while I'm having a cup of coffee. Right now I have presets 1-3 on 3sixty configured with Andy's (jbl), Crutchfield's and Audyssey's with t/a for the driver's position and the 4th preset flat w/ no DSP just for comparison.
#66
haha yeah that was when I was first playing with it and didn't have any thing to position the mic with. At first I had the base of the mic wedged under the seat head rest pointing forward but it kept falling down. then i found a bolt that fit in the stand mount and just stuck it in there temporarily. I probably should of mentioned that. Now I have a longer bolt with a big washer on it that goes behind the head rest. Works for now I guess.
#67
So despite my earlier picture which was when I first got the mic and was playing around with the RTA. This is how I've actually been using it. Yep, not really ideal either as it's positioned too low and forward.
So today while I was at home depot picking up lawn fertilizer I decided to grab a some stuff to make a mic stand. This is what I came up with. Cost me about $6 in parts. It's nothing fancy but the mic can be adjusted up and down and forward and back for better positioning.
#68
Glad my thread got taken over by things that aren't even affiliated with my topic.
Purchased an MS-8. Heard some TL owners have some issues, some don't. As long as I unplug the mic and hook up the signal (before) the amp? I've read hooking it after the amp creates issues.
#69
Before the amp. All you need to use is the front left and right channels unless you want the navi prompts, use the center too. Level match using the gains on your amps as best as you can before running a calibration.
#70
hey guys dont forget the Zapco products, The DSP8 is a great value and the performance is there, My 2 modded dsp6's have never had issue's
and fast 150mph, - PLEASE - try spinning the dial on a modded BUSA.......
I had high speed recall and the speed-0 commander for correct speed calibration and one insane late night for 96 seconds I did warp speed with the dial pegged.....estimated at 186-191
my old bike !!!
my old bike !!!
#71
my old bike !!!
my old bike !!!
#72
Alrighty - Thanks for the help. Set gains before calibration. Check!
Soul_Deamon
11-13-2018 05:44 PM
Zonian22
11-14-2015 02:20 PM
Oakes
Wash & Wax
10-12-2015 12:17 PM
