Factory audio integration Sound Processors
With so many users on here and almost all of them would like to retain their factory head unit, I thought this would be a great post....
Now this might have been asked, but I could not find anything specific regarding diffrent brands.
I hope that everyone will chime in...
The only think that I request, is no brand name bashing.
there quite a few of these devices.
Alpine PXE-H650
Overview: The Alpine PXE-H650 System Integration Audio Processor accepts input from nearly any factory or aftermarket radio, removes any existing equalization, and adjusts to overcome acoustic shortcomings of the specific vehicle's interior. A preamp signal then feeds your aftermarket amplifiers and speakers, allowing a substantial sound quality upgrade without sacrificing any OEM features (CD changer, DVD system, satellite radio, Bluetooth integration, etc).
Manual
Reference Guide
Audison BitOne
The Bit1 is controlled by a separate remote control module conveniently designed to fit nicely in most automotive ashtrays, with user-programmable presets for custom EQ settings. The system is set up via PC and features 8 channels of high level speaker inputs, RCA inputs, or a single Tos-Link fiber optic input.
Arc Audio
SRI - ARC SRI OEM Integration Module
The SRI based on a 6 channel signal summing module features 6 channels of hi level input plugs, AUX RCA input with remote level control, Selectable RCA/Balanced output plugs, 8 volt output,stereo full range output, and input level setting utility disc. Using a very simple and versatile system setup utility it takes the complication and confusion of other manufactures integration pieces and allows for a easy and time saving installation and calibration of the SRI to most any factory system.
Audio Control
There are quite a few models from Audio Control. If interested look here
Rockford Fosgate Rockford Fosgate Interactive signal processor
3Sixty.1
The 3Sixty.1 is the most advanced OEM integration processor on the market. Its advanced artificial intelligence allows the use of aftermarket car audio equipment to be utilized with virtually any OEM source unit. In addition, auto-equalization processes overcome and correct for OEM response inadequacies. There's also an auxiliary input for an iPod or other external audio device.
Manual
3SIXTY.2
The 3Sixty.2 delivers unprecedented control and flexibility to aftermarket and OEM sound systems with up to 153 bands of equalization and signal manipulation. Offering a fully interactive touch screen wireless solution via optional Bluetooth enabled Palm OS or Windows Mobile devices (select devices supported and not included), give users the ability to tune a sound system in real time anywhere within the vehicle.
Manual is the same as for 3SIXTY.1
Phoenix Gold
Phoenix Gold Tantrum TLD66
The Phoenix Gold Tantrum TLD66 enhances the output of any headunit. This professional quality line driver accepts up to 6 channels of output from your head unit and transmits up to an 8 volt signal to the amplifiers. The benefits are two-fold: Dynamic range is increased and unwanted signal noise is reduced.
Jl Audio
there are 3 -4 units from Jl Audio. if interested here is the link
JBL MS-8
The MS-8 is designed to provide a realistic soundstage to every listener in every seat of the vehicle. The heart of the MS-8 is a proprietary equalization algorithm that provides the competition grade sound quality that the MS-8 can deliver. The MS-8 also uses Lexicon's Logic 7 soundstage enhancement processing to create a seamless front image for all of the listeners.
Massive Audio
The FLATLINE by Massive Audio is an 8-channel hi-end line-output converter that will allow you to add aftermarket products to your OEM stocked vehicle. This unique product will convert your speaker level signal from a factory installed amplifier or head unit to a high quality, low noise pre-amp signal with summing options for additional flexibility. Now hook up that I-PODTM or MP3 Player directly into the dash mount remote while still using your factory head unit and turn that stock radio into a Massive Sound System!
Manual
MTX
MTX have two units one is REQ5 and REQ8.
They have a cool web site. Here is the link
Zapco
DSP6-SL Zapco 6 Channel Digital Processor
The DSP6-SL is a 6-Channel Digital Processor that provides Crossover, Equalization, Q-Bass and Time Delay for each channel. The channels are processed by six discrete processors which can be adjusted in stereo pairs, or individually, to meet the demands of each installation. The DSP6SL uses three SymbiLink™ connectors for the main analog inputs and also has an optical digital input. For an auxiliary analog source we have also provided a set of 2 channel RCA inputs.
Manual
I know there are quite a few more, if you guys/gals know of any? then please let us know.
Alpine PXE-H650
Manual
Reference Guide
Audison BitOne
Arc Audio
Audio Control
3Sixty.1
Manual
3SIXTY.2
Phoenix Gold
Jl Audio
JBL MS-8
Massive Audio
Manual
MTX
Zapco
Manual
since audio control have quite a few different models. I linked up their website. it is right after arc audio.
but here is a ? for you, or any one else. are there any other processors? I thought Kenwood made one, but it is only to integrade an ipod. surely there are more but not to my knowledge.
'04 TL SSM
Haha thanks fade, seeing as i just asked this in my first post. :-P
What would be your "best value for the money" pick?
And as far as my understanding goes, the JL models all piggy back off of their one Cleansweep CL441-dsp. If thats not installed the others have no use. correct?
Mike, they are all good. it all depends on what you mean by "best value for the money" diffrent people have diffrent budgets.
as for myself. I would pick phoenix. cause for around 60 - 70 $$$ it is hard to beat it.
according to the manual
cl44dsp accepts up to 4 channels of input from OEM audio source.
The Audison BitOne gets my vote. Time Alignment, Auto EQ similar to the Denon Home Receivers, Optical input, etc, etc. Audison is writing apps to be able to control this beast through the CarPC. Not the best bang for the buck at $1,200.00, just the best. An audiophile grade processor.
The 3sixty.2 would be my second choice.
Alpine PXE-H650
Manual
Reference Guide
Audison BitOne
Arc Audio
Audio Control
3Sixty.1
Manual
3SIXTY.2
Phoenix Gold
Jl Audio
JBL MS-8
Massive Audio
Manual
MTX
Zapco
Manual
Alpine PXE-H650
Manual
Reference Guide
Audison BitOne
Arc Audio
Audio Control
3Sixty.1
Manual
3SIXTY.2
Phoenix Gold
Jl Audio
JBL MS-8
Massive Audio
Manual
MTX
Zapco
Manual
Thanks for the post, would these items be the same as the JL clean sweep? Would your PHoenix rec be comparable in quality to the JL product? (THe JL one is $300- you could save me some $)
Gary,
reason I answered with Phoenix is do to the price point. JL is good as any other one. it seems that your heart is set on the JL, or you would not bring it up so many times.... just remember that it only does 4 channels and if you do want to retain your center channel.... you can leave it on the factory amp.
added to the 3G audio FAQ
Retired!!! ON TOP!!!
If I ever do my audio over... I think I might use the Audison BitOne...
Gary,
Actually, I dont care about the brand, I care about the "best sound quality for the most reasonable price" I always ask about JL and alpine because that is what I am most familair with, just because that was what I had before.
But anyway, does the Phoenix do the 5 - channel? I have my center channel turned down anyway currently, I guess I am not used to it yet.
the pheonix is a 6 channel unit. your TL is 6ch as well
you have
front left center front right
rear left sub rear right
you do not have to use all the channels.
If you do not care about center channel then, take a look at MTX req. very similar to the JL
and it is a whole lot cheaper.
you have
you have
you have
What is your recommendation for an amp if I am planning on utilizing the 6-channel set up? I am assuming a 5 channel amp that can work with a center channel and a seperate sub amp, however I can only find one 5-channel amp to be used with a center channel - but it only works with an alpine head unit. Perhaps I am looking in the wrong places.
OP, thanks for this info. I'm so lost when it comes to this stuff that I gave up trying to find something that would work for me. Now I'm thinking about using a processor.
Wow this one is going to be hard.... Sugesting an amplifier is very dificult thing to do, as there are so many factors involved.
I will not mention any brands for right now. but I will mention this much.
there are so many amplifiers on the market, it all basically depend on you. your choise your cash. and do not let anyone tell you "oh get this one, my bro had one and it shook the roof....." b.s.
any amp can do this... but for how long before it goes into protection?
there are
1 channel
2 channel
4 channel
5 channel
6 channel
if you choose wisely, An amp can stay with you for many years to come. I know this cause I am still using the ones I bought back in the early 90's....
and no they are not for sale. they went throught so many cars, not even funny. and now they found a new home in the Acura TL.
with that said.
you need to ask yourself few questions.
1. how much can you spend?
are you going to keep them fore ever? if so, then price does not really matter(well sorta, I know everything within a reason). If you do get high end models, You will not replace them in a year or so.
2. how much space are you willing to give up for them?
amps need room to breath.
3. what impedience will they have to run?
remember the lower the ohm the more strain on the whole electrical system, more resistance equals more heat.
4. can the electrical system supply the proper voltage amperage? are you willing to upgrade, battery, wiring, and such?
I have seen plenty of times, where not enought current killed awesome amplifiers.
5. what type and how do you listen to your music?
6. will you ever want to enter local soud off, and see how your system stacks up's against others, and no I do not mean in SPL or do I? this one will open a can of warms.... hehehehe
There are plenty of 5 and 6 channel amplifiers that are freaking awesome.
one think to note is. if you are looking to get a processor then you do not need a crossovers or boost/cut on the amp.
One more thing to note. not only you need adequete space for amps but also for enclosure as well.
and as far as the connection goes. that should not be a problem, and does not matter if you are using a stock deck or your alpine head unit.
connection are from head unit to the processor to the amplifier or amplifers.
Thank you. Will do.
Reason I ask is because this is a new world to me. As it stands, I've spent the last 2 months trying to hunt down a BAD alternator whine. Guess what is was...the OEM amp. I bypassed it now and I've got no sound except white noise from having to turn my aftermarket amps' gain all the way up. Plus, the music sounds very flat...like the depth is not there. So I was wondering if the processor would add that back and in and up the signal voltage up so that I can lower the gains on the amps and adjust accordingly.
i too am seeking a way to escape this flat sound. i have looked at several forums on sound processors. i really want to know if adding one would make a great difference.
a car audio tech friend of mine told me to just skip the sound processor and add an amp and subwoofer.
Well, I have 2 amps and subwoofer and the problem is the signal I'm feeding them from my OEM radio directly is so low I have to have the gains on both amps at 100%, this produces a white noise that I can mask with a filter but the sound is not being eq'd. Not horrible, but I KNOW if my amps were getting a boosted dB level they would sound as they should.
Just placed an order from crutchfield for the audiocontrol matrix, supposedly very versatile and seems like a good quality product. I know crutchfield has a good return policy so wish me luck!
guys, i just attempted to install my sound processor, but its giving me problems. i have searched the forums but i get dead links. does anyone have the head unit's wiring harness diagram?
Something to add on the Zapco list is the DC amps. Same processing as the DSP 6 per channel but all in one chassis. A DC650.6 will give you 6 channel processing and 6 channel amplification in one unit. Or you can do as I did and run multiple DC amps. You can link them into a network and use one controller to make changes in all units on the network. You can even e-mail the settings. I can e-mail all my settings and anyone using the same channels for high/mid/low. Download my settings directly into theirs and it is done. Only fine tuning per individual preference.
Kirk
Kirk
update.
sorry for grammer in advance.
since my initial post, i wanted more out of factory system. I also wanted to retain stock deck.
I bypassed factory amp and ran outputs straight into crossover and on to amps. system sounded good but not great, it was missing something that I can not explain.
I was looking for a Sound Processors for a low price. Other week came across a deal I could just not refuse. I picked up Alpine PXE-H650 for 100.00 and some change. Installed it last night.
All I have to say it is incredible. the sound or certain frequency that was missing is a thing of the past.
If anyone wants incredible sound check this unit out.
update.
Are you line driving also? Is that what the Alpine did you for you? Boosted signal?
no I am not using line drivers. I pulled all gear out, eq's and crossovers.
all from audiocontrol.
my signal is from radio to alpine unit then straight to amps.
the signal is not boosted rather corrected.
for initial setup and not messing with any settings yet, it sounds awesome.
this unit added stage, dimension and depth with out any coloration(echo sound) it also added midbass that I was trying to capture with eq's and crossovers. it's not that i did not have midbass, but rather like it could not capture it or reproduce it the way i wanted it too. I spend countless of times with rta and could get one thing but would mess up something else(sound wise). it is very hard for me to describe this. guys at local store thought i was crazy... perhaps i am.
as far as I am conserned(my opinion only) with this unit, or similar one. proper speaker placement is a thing of the past.
go to alpine dealer or similar and hear it for yourself. you will be amazed.
Awesome man...that sounds like the ticket. But I looked it up and MAN is it expensive. You got a killer deal!
Good job. The issue you're describing is exactly how I feel. But I think I'm going to stop messing with/spending money on it for a while.
CheeseyPoofs McNut
10-11-2015 11:25 AM
09-17-2015 09:01 PM
3602, acura, audiocontrol, audison, bit, bluetooth, factory, integration, lc7, mdx, mtx, processors, req, rockford, sound
