Easiest/Least expensive way to add Aux Input on 04 TL ?
Hi guys. I had a PIE X3 unit that stopped working when I connected/disconnected the battery. (already discussed in another thread...I contacted logjam and it is a known issue but rare--and if you are out of warranty you are SOL)
So rather than shell out the money for another X3 I am looking for the simplest way to just add in one Aux input. I dont care if it displays on the screen or not...I just want to use the XM input for my Sirius stiletto. I want to use that radio specifically. So I have the power and antenna already wired
under the dash...couldnt I just have a cable output from my sirius stiletto into the XM input on the back of the stereo or do I need something in between ?
4 bosh relays.
some wire.
a swirch.
by using relays it will not display, but it will sound as good as xm.
now you are going to ask for info on how to.
you can obtaing that info, by reading this sticky: 3G TL Audio & Electronics FAQ.
all the info is in there and I am actually using it for an ipod/zune input... works pretty darn good.
the Easiest/Least expensive way to add Aux Input on 04 TL..... is drum roll please.......
4 bosh relays.
some wire.
a swirch.
4 bosh relays.
some wire.
a swirch.
sound will be the same.
any how here is the link https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-audio-aux-577329/ on the whole tread...
once complete let me know what you thing of this....
was to lazy to look it up, but done it anyway.
any how here is the link https://acurazine.com/forums/showthread.php?t=577329 on the whole tread...
navtool.com
31
11-16-2015 08:30 PM
soupi
14
11-15-2015 11:15 AM
navtool.com
09-25-2015 05:15 PM
