dvd-a help???
dvd-a help???
I made an iso file using adobemans gui I have tried alcohol120 , deepburn , dvd solo and none of them will burn the iso file to disk??? Someone please help!!!
Is there something i have to do to the iso file or just find a burner that wil burn it to disk???? Thanks!!!!!!!!!
Lt. Dangle
2) Lower your burn speed to 2.4x
3) Try different DVD-R media
If none of those steps work, you might try a different burner.
Has anyone burned a dvd-a with ULEAD BURN??? I got it to burn but havent tested out in the tl yet??
AVB for President!
I used Nero 6.6 to burn mine. Its worked flawlessly so far. The burn speed is 4x, although just as a test, I'm going to see how 8x will do, since the DVD blanks that I bought are supposed to be pretty good (supports up to 16x).
Just to clarify, Ulead Burn.Now 2.0+ will allow you to create DVD-A disks as well as burn typical CD/DVDs. No additional DVD-A software required.
Nero (my burning software of choice) will allow you burn CD/DVDs, but can not create DVD-A disks on its own. It is able to burn ISO's created from other DVD-A software.
I found a program called imgburn its free and burns iso files from adobemans gui perfect!!
Im getting a new light on dl dvd burner with lightscribe hope to speed the process up a little!!! Thanks everyone for all the suggestions!!
acuralvr1
67
05-26-2007 09:35 PM
skidrow
04-11-2005 02:04 AM
