Download phone book
Do any of you know when you click "store in HandsFree" (I think that's what it says) what does that do? I've done it to a few numbers and still couldn't figure out what it does. I checked my HandsFree phonebook and have no new entries so I'm just curious on how that works.
Received 6,470 Likes
Whistler, you can download your entire iPhone phonebook via the center console. Press the "Info" button and then press the cellular phone button and then hit the "Import" button. Your iPhone must be already linked to the car's HFL.
Keep Right Except to Pass
It depends on what year the OP's TL is. The 2004, at least, does NOT allow these things; I believe the 2005 does not either, although I'm not sure about that.
I had a question about this feature....
On an incoming call when the phone is connected to HFL and the phone book has been downloaded, should the display or MID show the number AND name of the person, or just the number?
If so I'm not really sure as to the usefulness of being able to d/l the phone book into my car... Am i missing something (usually am) ?
Balling in the...
Mines only shows the number. Its weird cause the Navi and the HFL don't work together. You would think my phonebook is stored and it should show the name on the display. I only use my phonebook in the navi when i want to call someone without using my phone. Usually that doesn't happen much since i like doing things quicker then searching through menus for a number.
The Navi and the HFL DO work together in some respects. If you program a personal address and add the person's phone number, you can bring up his listing on the screen and then press or say "Send" to send the number to the HFL to place a call. Same goes for businesses listed in the Navi database.
My HFL never shows a name regardless of whether the caller ID info transmits one. Sometimes it shows a number, sometimes it doesn't, and it's not clear to me how it determines when it will.
av2600 (07-10-2011)
mlody
12-04-2019 02:11 PM
joflewbyu2
08-18-2019 10:38 PM
