Hello,
I had my TL for like a month already. Its 2004 with 52K miles. The problem is with navigation system having like small dots across the bottom of the screen. The dots are transparent. This only happens with Map Setting only. I can go to different options like audio,setup and it dosen't show dots.
What should I do?
Is it possible to reboot the Navigation or Resetting it?
Call Acura?
Fucked?
-Chris
What should I do?
Call Acura?
Fucked?
-Chris
Will Y.
Registered but harmless
close
- Join DateAug 2005
- LocationLos Angeles, CA
- Age61
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:1,164 Times in 786 Posts
Turn off the "breadcrumbs." Do a thread search here or look in the Nav manual for it.
The '04 Nav manual is available through the 3G Garage here too-- just click on the link at the bottom of the onwer's manual link.
csmeance
close
- Join DateFeb 2006
- LocationSpace Coast, FL
Liked:2,185 Times in 1,569 Posts
do these dots run about 1/2 inch tall, across the bottom of the map screen? If yes, this is the area in which the street name you are currently traveling on is displayed.
Quote:
yeah, you nailed it.Originally Posted by csmeance
Happened to you also?
