DOMs Unit and lines on screen help
Ok i thought i saw a thread about this problem a while ago but i cant seem to find it so ill just ask the question.
I installed the DOMs unit to my navigation system and when i have my iphone displaying or any video displaying on my screen the video shows and when the car is stationary for the most part the screen is clear, however when i start to drive i see horizontal lines moving up and down my screen. WHen i accelerate and sometimes when i hit a bump i will see the lines, when im just cruising i dont see them as much and when stopped if the car isnt vibrating from a cold start it will work fine. Can anyone help me out with this.
Im thinking it might be the grounding of the cables, not sure though. Help would be greatly appreciated.
try hooking up a dvd player to the video out. see if you get the lines. if you do then check the grounds. if no lines appear then its the iphone cable. good luck, hope this helps
its possible that the iphone cable might be the issue? when i hooked the iphone cable up to the tv it worked fine. I did hook the wii up to my DOMs unit as well but i cannot remember if there were lines or not. Im going to try it again. I dont think there were any lines. Ill try this out this weekend.
If it is the ipod cable, which is an original cable from apple, how would i fix that?
it's electrical interference. First try using shielded cords from the IPOD to dom's, and see if that eliminates the issue. If not, then it's something to do with the wiring for doms. Check your wiring and grounds, be sure that it's metal to metal and not metal to paint contact.
I had this problem once and found out that my Dom's unit had fallen from where I had it installed so it was moving around freely as I drove. I had moved were I had it placed and its bolted pretty good now. I used Industrial strength velcro to mount it in the trunk. So check your unit and make sure its mounted pretty tight and not moving around
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
acura, acurazine, acurazinedoms, doms, horizontal, lines, mdx, navigation, screen, tl, tvandnav2go, unit
