DOMS NAV2GO + Backup Camera Issue
Sexiest NBP.. inthemaking
Hi everyone,
My current setup consist of:
-Doms Nav2go
-Dice Unit
-Backup Camera
Couple days ago when i was backing up, i noticed my camera didn't turn on when i put my car in reverse like usual, i didn't think anything of it. Usually it glitches out every now and then. It usually fixes itself. Not so lucky this time.
When i turn my car on, the stock navi will pop up and everything would work fine, Untill i put my car into reverse, a black screen would pop up instead of the backup camera. Not only does it not work, once it pops over to the black screen, it doesn't pop back over to the stock navi when i take it out of reverse. I dunno what the issue is. I Also have another video sourced connected to the Dom's Nav2Go unit, and when i switch it over to that source it also gives me a black screen, this also doesnt let me return to the stock navi. Only way i can get my navi back is to restart the car.
I have the doms unit tapped into my cig lighter, i chekced the fuse on that and its fine, i have no clue if its a fuse or what. I am assuming the doms unit has died on me. This is the only problem i can think of.
If anybody have an idea what could be the problem, please give me your input. I also have one question, did the nav2go come with a fuse? i dont rmb it having one when installing the unit. Its been awhile, if there isnt a fuse for that i guess im out of luck,
Thanks....
-Doms Nav2go
-Dice Unit
-Backup Camera
Thanks....
Team Anthracite Webmaster
my nav2go had an inline fuse on one of the power leads, i believe. but yeah, it does sound like your nav2go is kaput. if you had the plug and play kind maybe try taking it out.
Okay guys, this is really wierd. As I was leaving for work this morning, my seats did not auto adjust to my setting. Also my kms for trip a and b were reseted to 0... Not only
That but when I was backing up i saw my camera work but it was really dark and I can only see the top of thr screen ... When I put it back into drive my stock navi actually came bak!
Things were looking good until I got to work... As I was backing up into my stall.. Same issue reoccured... No camera + couldn't get back to navi.. Stuck on black screen .
So I was wondering could it be that my battery is not giving up enough juice? Or is it still my doms unit?
Thanks guys
Thanks guys
Which fuses do you guys suggest I check? I looked at all the backup/navi fuses..
Seriously this is freaking me out guys, 3 straight mornings the camera would work while backing up and for the rest of the day it would NOT work. It works half ass, like your flashlight when the battery is low. Screen is extremely dark. It seems as if since my car sits in the garage for 12 hours it charges up the dom unit or something...
Should I take my cAr apart and look? Or should I leave it and see if it fixes it self?
Check your BATTERY. Goofy shit like this happens when you have a low battery.
Also, when my Nav2Go was acting up, I disconnected the battery for 5 mins (make sure you have your codes) and all was well again. I had to replace the battery like 2 weeks later.
Soul_Deamon
11-13-2018 04:44 PM
BoricuaTL
04-08-2016 01:08 PM
09-17-2015 09:01 PM
