Does HFL pair Blackberry gateway the same way it does a phone?
i've been having problems pairing a phone with my '05 acura (as seen on my other thread https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/what-would-you-like-name-device-846666/) and i decided to spend my last $200 towards a good music streaming device instead of getting a new hfl module (cause everything else works except for the pairing process), and i wanted to go with the blackberry gateway......but i figured since the blackberry is a bluetooth device, wouldn't it need to be paired with hfl also??? i know that i would not have to pair my phone to the car, but to the gateway which is great, but the gateway has to be paired with the car right???? (i wouldn't know cause i haven't been able to pair anything to my acura yet) ............ so am i correct to think that, if i wanted to install the gateway and stream music from my phone to the car, basically i would have to replace the hfl module??? (i know all this might sound retarded and obvious for those of you who've gotten all these things set up and working fine and dandy, but i have no clue as to how this might affect me with my faulty hfl unit.......and yes, i've checked the threads, and no one has this problem) please bear with me......thank you
Being an Acha Bacha in
I've discussed this in detail already in this thread very recently:
https://acurazine.com/forums/showthr...uetooth+stereo
Short Answer: yes it will work fine w/ no conflicts. Post in the other thread so all answers/info are available to see in one easy thread.
mlody
12-04-2019 02:11 PM
ExcelerateRep
10-14-2015 08:20 AM
phillyguerrilla
09-26-2015 11:27 AM
