Does anyone know which color wire is for the headlights?
Old Dec 2, 2007 | 08:50 PM
V-tec's Avatar
Does anyone know which color wire is for the headlights? please and thank you.
Old Dec 2, 2007 | 11:10 PM
csmeance's Avatar
where exactly are you looking for the wire? It changes color from fuse-box to light-box and so forth.
Old Dec 3, 2007 | 12:21 AM
V-tec's Avatar
the fuse-box or anywhere inside the car would work fine. if can, can i get some pic so i know where to look for please and thank you
Old Dec 3, 2007 | 08:31 AM
zax123's Avatar
Team Anthracite Member
Here's a howto I posted a while back on how to install auto-headlights. It should help you:
https://acurazine.com/forums/showthr...uto+headlights
Old Dec 3, 2007 | 06:01 PM
V-tec's Avatar
doesnt really help. i want to use the headlight switch to turn on my LED light inside of my car so i wont have to make a switch for it.
Old Dec 3, 2007 | 06:12 PM
csmeance's Avatar
Tap the fuse for the headlights in the fusebox with an add a circuit from autozone. The fuse is labeled inside the cover, this is the interior fusebox
Old Dec 4, 2007 | 12:42 AM
V-tec's Avatar
i read the interior cover labels but it doesnt have anything the is label as headlights fuse. Do you which fuse number i should use? please and thank you
Old Dec 4, 2007 | 09:07 AM
zax123's Avatar
You can wire a relay to the wire that gets grounded when the headlight switch is turned on (that wire is identified in my howto). Then you can turn on your LED using that.
Old Dec 4, 2007 | 04:49 PM
V-tec's Avatar
The relay is locate under the hood in the fuse box right?do you know the fuse number for it? i`m new to this. sorry for asking so many question. dont want to fk up.
BoricuaTL
Apr 8, 2016 01:08 PM
pistacio
Sep 26, 2015 09:45 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
Phambam12
Sep 6, 2015 06:57 PM
