(DIY) Switchback turn signal with factory side markers
performace tl-s
Hello I know allot of people done this before I search allot too but didnt find anyone that done this and was able to make the side markers blink at the same time with the turn signal when the parking light are on. From 1 to 10 this is a 4 on dificulty.
This wiring is specific for 07/08 tl s
same steps for 04 to 06 but may have different wire color
Parts
2 relays
2 diodes
18 guage wire
1-First remove the cover of the steering wheel
2-locate this connector behind on the wiper controls unit
![Name: 20140913_170348_zpsyhwak5ew.jpg
Size: 55.3 KB](https://acurazine.com/forums/attachments/3g-tl-audio-bluetooth-electronics-navigation-94/77739d1501528237-diy-switchback-turn-signal-factory-side-markers-20140913_170348_zpsyhwak5ew.jpg)
3-splice this two wires they are the left and right turn signal this colors are for 07/08 tl s .
![Name: 2014-09-15%2015.36.50_zpsaegoh9t4.png
Size: 118.2 KB](https://acurazine.com/forums/attachments/3g-tl-audio-bluetooth-electronics-navigation-94/77740d1501528237-diy-switchback-turn-signal-factory-side-markers-2014-09-15%252015.36.50_zpsaegoh9t4.png)
4- pass this wire that you just splice to the engine compartment .
![Name: 20140913_171354_zpsp3jvuqez.jpg
Size: 54.2 KB](https://acurazine.com/forums/attachments/3g-tl-audio-bluetooth-electronics-navigation-94/77741d1501528237-diy-switchback-turn-signal-factory-side-markers-20140913_171354_zpsp3jvuqez.jpg)
5-now remove the side marker from the fender and cut the positives wire black/red .
![Name: 2014-09-15%2016.13.53_zpsqs7te3vw.png
Size: 115.2 KB](https://acurazine.com/forums/attachments/3g-tl-audio-bluetooth-electronics-navigation-94/77742d1501528237-diy-switchback-turn-signal-factory-side-markers-2014-09-15%252016.13.53_zpsqs7te3vw.png)
6- now you have two wire one from the side marker and one from the car.
7- Now get your relay and make the flowing connection
connect the car side wire to connector #87a on the relay
Connect the side marker side wire to connector 30 on the relay
![Name: 2014-09-15%2016.25.09_zpsyuqxoy61.png
Size: 166.6 KB](https://acurazine.com/forums/attachments/3g-tl-audio-bluetooth-electronics-navigation-94/77744d1501528237-diy-switchback-turn-signal-factory-side-markers-2014-09-15%252016.25.09_zpsyuqxoy61.png)
8-now connect the two wire from the turn signal sitch to connector # 86 on the relay make shure to use a diode.
![Name: 20140913_200620_zpssnzh2cau.jpg
Size: 51.8 KB](https://acurazine.com/forums/attachments/3g-tl-audio-bluetooth-electronics-navigation-94/77745d1501528237-diy-switchback-turn-signal-factory-side-markers-20140913_200620_zpssnzh2cau.jpg)
9- connect conector # 85 To the positive side of the battery.
10-connect conector #87 to the torn signal wire at the headligh
![Name: 2014-09-15%2016.59.56_zps2zq3h0ch.png
Size: 140.3 KB](https://acurazine.com/forums/attachments/3g-tl-audio-bluetooth-electronics-navigation-94/77746d1501528237-diy-switchback-turn-signal-factory-side-markers-2014-09-15%252016.59.56_zps2zq3h0ch.png)
11-now that all the connection are done it will look like this.
![Name: Screenshot_2014-09-15-15-48-28_zpszw3im6j7.png
Size: 126.7 KB](https://acurazine.com/forums/attachments/3g-tl-audio-bluetooth-electronics-navigation-94/77747d1501528237-diy-switchback-turn-signal-factory-side-markers-screenshot_2014-09-15-15-48-28_zpszw3im6j7.png)
This is how it look
Acura tl type s side marker turn signal:
Parts
2 relays
2 diodes
18 guage wire
![Name: 2014-09-15%2016.40.17_zpstkxa7spy.png
Size: 183.1 KB](https://acurazine.com/forums/attachments/3g-tl-audio-bluetooth-electronics-navigation-94/77743d1501528237-diy-switchback-turn-signal-factory-side-markers-2014-09-15%252016.40.17_zpstkxa7spy.png)
This is how it look
wow, nice job!
Someone should move this to the General board =)
performace tl-s
Last friday After I saw gerzand writeup I got interested on finding a solution for the side marker not blinking at the same
with the turn signal at night I was working on the wiring sarurday then Sunday I decided to do it. It looks nice day or night.
