DIY: How to Make a Trunk Beauty Panel (a dummy approach to complex curves!)
Old Oct 16, 2011 | 05:31 PM
DeathMetal's Avatar
Fearless DIY Guy
For anyone who's ever slapped a sub in their trunk, I'm quite sure at some point in time you've asked yourself, "Should I do anything other than just tossing the equipment in there?" Well, there's plenty of members whom have done AMAZING work on their trunk, but you may be one of those guys whom took a good look at the trunk, looked at all the angles and thought, "YEAH, OK." and walked away none the wiser.
Well, I'll share with you one technique ANYONE can use and get you some damn good results for a very low cost. What I am going to detail is one approach to fabricating a beauty panel for the trunk. Let's proceed.
Props to Jamie (jplt04), you gave me the inspiration for this after I reviewed your approach to horizontal angles.
THEORY
If you examine the angles of the trunk, it's easy to see that accurately conforming to the shape is no easy task. I had thought of modeling the curves at one point in time, when it dawned upon me that the very math I was doing, and integral, aka a REIMANN SUM, could easily be replicated IRL with Popsicle sticks! Let's roll.
STEP 1 - CENTERLINE MARKINGS
Position your box and mark the centerline. THIS IS VERY IMPORTANT, DO NOT RUSH THIS STEP! Once you have your centerline marked, use some painter's tape to mark the line where the fron of your box will be.
STEP 2 - THE REIMANN SUM
A Reimann sum works by approximating the area under a curve through a series of boxes, if you will - we're going to do the same. Using popsicle sticks, stack them atop of one another using a hot glue gun and trace the shape of the curve you're going to need to cover with the panel. Taoe the first stick parallel to the centerline tape and start stacking.
You're going to stack the popsicle sticks IN A STRAIGHT STACK, GOT IT?! A STRAIGHT STACK. THIS ISN'T ROCKET SCIENCE, MAKE IT STRAIGHT UP. Push each stick to the left until it stops against the panel and walk it up to the top.
STEP 3 - TEST FITTING
Now take the piece and trace out the stack.
Test fit 'er up.
From here you can now go back and cut some new cardboard to fill if necessary.
STEP 4 - CENTERLINE MARKING FOR CUT
Remember that all-important center line I spoke of earlier? Well, here's where it really comes in to play. Once you're happy with your cardboard cuts, mark the center line of the board w/ the CL of the tape - THIS TELLS YOU WHERE TO MIRROR THE PANEL, AND HOW WIDE YOUR PANEL WILL BE.
STEP 5 - FINAL EXAM
Trace your carboard on your panel - I'm using 1/8" mason board since I need to bend this fucker to get it in (figures I'm at the widest point)
AFTER THIS STEP YOU ARE ESSENTIALLY DONE AND CAN MODIFY YOUR HOLES/PLEXIGLASS/LIGHTS AS YOU SEE FIT! HOPEFULLY THIS SHOWS YOU HOW TO APPROACH THE ANGLES!
STEP 6 - SUBHOLE
I really, REALLY suck at cutting holes in boards. REALLY suck. Here's my crap attempt. This will vary depending on your setup, but this is one method.
STEP 7 - FINAL REVIEW AND CLEAN-UP
Ok, well, it's damn good. Not perfect, but damn good. I still have plenty of board left over, and seeing as how the hard part is done, I will trace and cut a new one with cleaner angles and add maybe some cool plexiglass and whatnot. I'll post some more pics later once I determine how I want to liven it up, but I'm DAMN happy with the fit.
Old Oct 16, 2011 | 05:52 PM
guitarplayer16's Avatar
awesome DIY!
Old Oct 16, 2011 | 07:08 PM
CubanLynx84's Avatar
under renovations....
Very nice!! I'm getting a new box soon and was gonna make a faceplate to cover the sides to clean it up. Let me ask though, how hard is it to get that face piece out or did you split it in half. Cause I was thinking of splitting it so I can get the box out when needed cause I do carry the spare tire with me.
Also what are you using to secure it?
Old Oct 16, 2011 | 08:49 PM
DeathMetal's Avatar
Fearless DIY Guy
Ah, yes, let's talk a key point - FUNCTIONALITY! Now, if you split it in half you lose the "look" of a true beauty panel, so I used 1/8" mortar board - this stuff is light, flexible, and easy to take in and out...so if you forsee the need to remove the panel for life's contingencies, I recommend using it. I will also be cutting in some stealth panels that will allow me to access my wheel locks, roadside kit, and lifting belt, which are all staples of my trunk...I'll be detailing those items this week / next weekend as time permits me to work on this. Bottom line - flexible panels will give you the best of BOTH worlds!
Now, the real magic in this is that the fit is DAMN precise...so much so that by interference-fit ALONE it's well in position! I'll be using some velcro in key spots, more to come on this!
Old Oct 16, 2011 | 09:07 PM
You mean you used masonite. and yes it can bend very easily but over time it can become crappy. I really don't care for the look too much more so the functionality of it is more important. I was going to use 1/4" mdf probably and just carpet it up to match.
Old Oct 16, 2011 | 09:15 PM
DeathMetal's Avatar
Fearless DIY Guy
Whatever, it's late
Yes, it can retain a crap position over time, but I'll deal with that as it comes. But as far as making the template is concerned, I do recommend this method!
Old Oct 16, 2011 | 09:37 PM
Steven Bell's Avatar
Nice write-up DM.
Old Oct 17, 2011 | 07:15 AM
SharksBreath's Avatar
BANNED
thanks for the DIY and pics, dan.
i'm undertaking this project very soon with some MDF.
Old Oct 17, 2011 | 02:23 PM
maddsiick's Avatar
Mistuh DRiiVA
Looks like I wasn't the only one this weekend making a Trunk Beauty Panel. Not trying to hijack your thread DeathMetal, just wanted to show what I did this weekend too. It makes the trunk look so much cleaner than just having a box in there.
BTW major thanks to JPTL04 for all his help with this (advice and very detailed instructions), your trunk setup inspired me to attempt something like what you have and I don't think it came out too bad for a first attempt. Sorry for crappy phone pics...it was late at night when I finished.
Old Oct 17, 2011 | 02:46 PM
jptl04's Avatar
Bone stock tl-s
Dan, thanks for the thread, should help out alot of beginners here. Great idea. You could also use thin cardboard cut into slats like the sticks. And hot glue those.
Maddsiick, the trunk looks sweet man, came out great! Looks like there's 8 subs in your trunk! Lol! That mirrored plexi and clear rear wall makes any enclosure look super custom then add the led lighting. That's just icing on the cake! Again awesome job!
Old Oct 17, 2011 | 03:37 PM
maddsiick's Avatar
Mistuh DRiiVA
Thanks for the compliments...if it wasn't for you and Dan, the interior of my car would be completely stock. Can't thank you guys enough. Between the carPC, Navi Conversion, LED lighting guides by Dan, and Jamie's magnificent trunk creations, I don't know how I would have done all of this.
Old Mar 18, 2012 | 06:33 PM
Schweinsteiger11's Avatar
Just now found this DIY, and a great DIY it is (as usual by DM). I've been trying to think of a way to do this and this is a fantastic idea. Thanks for the method and all the inspiration!!
Old Mar 18, 2012 | 08:18 PM
niebur3's Avatar
FYI....it is soooooo much easier to just take thin cardboard (I use the cardboard from 24 packs of coke we buy), cut some big and small pieces and superglue or hot glue it the way you did. It goes really fast that way. Then transfer to the wood....measure in between the left and right sides so you know how much should be between them and you are done.
Good write up though!
Old Mar 18, 2012 | 08:27 PM
DeathMetal's Avatar
Fearless DIY Guy
Anytime, my friend. If you have any questions during your attempt, feel free to give me a shout.
Old Mar 18, 2012 | 08:57 PM
rockstar143's Avatar
Hey hey Dan...get back to yer kid!!!
We DO miss you on the forums, bud. Don't know how I missed this thread, but thanks!
J.
Old Mar 18, 2012 | 09:09 PM
DeathMetal's Avatar
Fearless DIY Guy
Hey, Jeremy! I see your thread is still hella active, one of these nights I'll be able to catch up! I was planning on another round of mods, but my tires are wearing prematurely , so I'm here for some good info now. (dip in here to check it out https://acurazine.com/forums/showthr...819556&page=10)
I'll be here more often these days, gotta figure out wtf is going on...and catch up on your ride, of course!
Old Mar 18, 2012 | 09:16 PM
Indeed, my friend. These poor saps have all had to settle for my sorry excuse for wit and sarcasm in your absence.
Tires, huh?!?! But you had it aligned?!
I went with continental contiextreme dw's and couldn't be happier, maybe look into the dws's?!!? I know Steven Bell swears by his.
Old May 15, 2012 | 07:53 PM
kingston-1's Avatar
THEORY
Test fit 'er up.
STEP 5 - FINAL EXAM
STEP 6 - SUBHOLE
hey im looking to install some subs this summer, i was wondering if you still had the specs from your build
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
PortlandRL
Sep 14, 2015 12:01 PM
