Disable HFL?
Old Feb 16, 2005 | 07:42 AM
DallasTL's Avatar
Disable HFL?
Is it possible to disable HFL while driving prior to making a call?
I am aware of the "transfer" command allowing me to transfer the call to my handset, but at times I'd like to initiate call and speak from my handset. If I dial directly from the handset now, there is a big delay before the call is connected which is frustrating to those I am calling. ("Hello? Are you there?") I have resorted to puling over and turning of the car (thus disabling bluetooth) to make a call. There has to be a better way...
Old Feb 16, 2005 | 01:09 PM
Contivity's Avatar
Goto your bluetooth setting and press disconnect
Old Feb 16, 2005 | 04:39 PM
DallasTL's Avatar
It won't let me disconnect Bluetooth connection if active. I've got a SE T637 and the only way to shut down Bluetooth is if the phone doesn't register a connection.
Any other ideas?
Old Feb 16, 2005 | 04:59 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
Can you just dial and call from the phone or does the HFL automatically take over?
Old Feb 16, 2005 | 07:03 PM
DallasTL's Avatar
You can dial directly from the handset but there is major lag time between when I hit "send" to when I can hear the person I've called. By the time I hear anything in my handset, the person I've called has already answered and is in the "hello, are you there?" stage of the conversation. Not usually a big deal, but bad for business calls.
Old Feb 16, 2005 | 07:46 PM
Modeler's Avatar
Just like you have the T637 and have not experienced this problem. As soon as I hit the Send button on the phone, I issue the Transfer command and the call is transfered to HFL before it's picked up almost every time.
Old Feb 16, 2005 | 09:56 PM
DallasTL's Avatar
By issuing the Transfer command, do you mean the verbal command?
Old Feb 17, 2005 | 07:31 AM
Modeler's Avatar
Yes. Is there a different way? Please, tell me if there is.
Old Feb 17, 2005 | 11:48 AM
onalake's Avatar
I have used the transfer verbal command and it has worked quickly and effectively each time.
joflewbyu2
Oct 8, 2015 11:16 AM
phillyguerrilla
Sep 26, 2015 11:27 AM
rmittal
1/2G MDX (2001-2013)
Sep 19, 2015 08:41 PM
Markbby06
Sep 17, 2015 02:30 PM
kuzdu
Sep 10, 2015 08:42 PM
