Dice aux input question
I did search to find my answer like I usually do but i did not come across the answer to my questions. Anyhow... I plan to run the dice r4 unit non silverline. I already have a dom's unit for my video output, would i be able to use the aux input on the dice unit for the audio source for my video? I know i would have to get a rca female to 3.5mm input since from my understanding that is what the dice aux unit accepts. Any help would be greatly appreciated.
thank you
thank you
I dont know for sure, but I would assume it would work.
All you need to do is to get Audio from the external source to the radio, and the Dice input is built to do exactly that.
It's probably talked about in those huge threads..but maybe someone else can reply for sure.
hey 3gLT,
I already the dice unit as well, im planning to use it's aux for audio with my dom's unit. Im pretty sure this works, u would have to just turn the aux on first, and then the video source!
Absolutely.... you would be able to use the Dice Unit's Aux input for your DVD player.
I'm currently using it to do just that... it works perfectly and the sound quality is great. The Dice unit also lets you adjust the Aux gain, bass, treble and midrange too...
Good Luck and happy modding...
=O oh really? how would u happen to do that?! control bass treble and stuff
When the DICE's AUX input is selected, DISC1-4 (Preset1-4 if in SAT mode) will adjust Gain, Bass, Mids, and Treble with the next track/seek up buttons.
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
