Dialing but Not Talking via
Old Aug 31, 2005 | 02:37 PM
Roman Zolin's Avatar
TL Photographer
I have a weird case (as I think). I call from the car via HFL, it starts dialing my Siemens SX66 and then nothing. I have to use the phone to talk not the HFL. But before (like 3-4 calls) it worked just fine. Does anybody know what could go wrong? May be there are some settings in the HFL I could screw up? I haven't changed any settings in the phone, but played with the car (so many buttons and dials )
Old Sep 1, 2005 | 07:15 AM
jmbnova's Avatar
How may I help you.....?
Go into your phone and delete the pairing you have with the car... Then re-pair it to the car and see if that helps... Sometimes they trip over themselves and dont connect, once they do it the first time they tend to do it more and more... just re-Pair it to the car... should work
Old Sep 1, 2005 | 07:21 AM
lowws6's Avatar
Sometimes my phone will not link with the car for no reason. I just turn my phone off and then back on and it works fine after that.
Old Sep 1, 2005 | 07:56 AM
DMZ's Avatar
DMZ
Head a da Family
Have you tried downloading and installing the latest SX66 ROM upgrade?
http://communications.siemens.com/cd...0.html#content
I had the exact same bluetooth issues with the Verizon/Audiovox version of the phone until I updated.
Old Sep 1, 2005 | 09:36 AM
jmbnova's Avatar
Are there different versions of Bluetooth? I Have a Motorola V505. I was wondering if any of you guys can dial with the phone but have it work through the car... In other words use the phone manually to select a number, hit send and have it connected through the bluetooth? I wasnt sure if changing my phone would change the way it works.....
Old Sep 2, 2005 | 05:08 AM
TL Photographer
DMZ, thanks for the update I will try it. As well I will try to re-pair it.
I wen to the dilership and it seems that this phone wasn't approved by Acura - it is working randomly.
knight rider
Mar 4, 2016 08:59 AM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
thegipper
Sep 28, 2015 01:01 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
